Bring back good 14mm's
Re: Bring back good 14mm's
Postby spencerdiesel » Mon Feb 29, 2016 5:00 pm
Is that why the rockentechs don't live? Or is it tolerances?
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Postby RCCUMMINS89 » Mon Feb 29, 2016 6:54 pm
I would assume it has something to do with both.
Postby JQmile » Mon Mar 07, 2016 12:32 am
There's actually a number of Rocken Tech's that have lived.....there's even a few non-Internet guys running 'em here in California, but they're turned down.
JQmile
Postby spencerdiesel » Mon Mar 07, 2016 7:40 pm
So something like 50 psi inlet pressure and the screw hanging out of the pump? :lol:
Postby jdiesel_us » Tue Apr 05, 2016 4:19 pm
I love my ve pump but if crazy horsepower is your game the p pump is a much more reliable solution and isn't reliability why we love these old engines.
jdiesel_us
Postby motorwood » Tue Apr 05, 2016 5:37 pm
The Rocken works fine if you feed it like Brian said to, back in the day.
'03 2500: utility body stock; '92 350 flatbed: maxed fuel, 354 spring, 6x.016's, 14mm H/R, 2.8plate, studs, springs, A1000 5/8 line, Super40 = 454hp 1080tq all fuel. Have added S3 66/74/.91, O-rings, home port job, Steedspeed t-4 manifold. Hp=437/857 :( 13mm P, 5x.025, he551+ht80 843hp 1thousand something trq. Broken 5th gear.
motorwood
Postby Rob_O » Fri Jun 24, 2016 3:25 pm
Rob_O
