slightly off topic vw ve pump question
Postby burnt_servo » Thu Dec 27, 2007 9:59 am
firstly i'll aplogise for this being slightly off topic.... but it is about a ve pump , on a 1990 vw jetta , 1.6 litre .......
anyway here is the question ;
after reading about the pin and cone mods here , can the same be applied to the vw pump ?
did a search yeasterday on google for a few hours and came up with little , very little .......
like the 1st gen dodges , the older vw's have fallen off the radar in favor of the newr models .
anyone here have any experience with vw diesels ?
i'm also curious at what boost pressure i might have head gasket problems .... can the head or block be o ringed ?
i emailed a few diesel places and their responses have been , " we don't work on stuff that old " .
right now i'm running a 2.5 inch exhaust , kn filter and turned the pressure screw up about 3/4 of a turn , and played with the govener settings abit .
running 15 pounds of boost ( up from around 10 ) .
working on a water cooled intercooler when i get some time .
thanks to all that respond :)
burnt_servo
Postby cummins king » Thu Dec 27, 2007 10:58 am
the only real difrence between the two is is 4 out instead of a six out, prety much everything else is the same, you sould search for forms on the vws i know there is some and they will be able to help you,
as for boost pressure i couldnt tell you, but you can o ring almost every head.
93 4X4 auto
cummins king
This might help ya
Postby roxxx » Thu Dec 27, 2007 1:39 pm
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Re: This might help ya
Postby burnt_servo » Thu Dec 27, 2007 2:42 pm
roxxx wrote:http://www.vwdiesel.net/phpBB/index.php?sid=c432d66c794789319086308118ce339a
thank you very much ...... don't know how i missed that forum .......
only problem now is i want to tear into my car now ..... AND start fixing my truck ......now if i could figure out how to not need sleep i'd have it made :D
burnt_servo
Re: slightly off topic vw ve pump question
Postby meby » Wed Jan 09, 2008 2:25 pm
burnt_servo wrote:firstly i'll aplogise for this being slightly off topic.... but it is about a ve pump , on a 1990 vw jetta , 1.6 litre ...
IIRC, after around 18 to 20 lbs of boost you have to start upgrading things like turbos and heads.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
