Time to retune
Time to retune
Postby cougar » Thu Apr 14, 2016 9:17 am
Finally got around to installing the hated 7X.010 injectors in my 92. Didn't have time to do any tuning as it was late and I had to get home. Going for a towing tune like I had on my 91.5.
First thing I have to do it turn up the idle, right now it won't. As it sits, if you get on it even a little it's light out for whoever is behind you. No smoke or haze cruising or at idle. So, I'm going to bump the timing a little, then play with the pump settings for a while. Then back to probably reindexing the throttle lever (if I can) and resetting the idle screw.
01 2500 "the work truck".
cougar
Re: Time to retune
Postby ellis93 » Thu Apr 14, 2016 6:44 pm
They're not hated.....not by me :lol: I like mine just fine......once the pop pressures are set right they do fine.
Where the timing at right now?
Re: Time to retune
Postby cougar » Fri Apr 15, 2016 8:17 am
The truck was bone stock when I bought it. The only things I've already done so far is swap out the turbo to the modified H1C I had (GDS 60mm compressor and 16cm2 exhaust housing) and modified fuel pin. I also turned the fuel screw, but it was only a quarter turn until it hit the collar. Timing has not been touched and injectors were original.
cougar
Re: Time to retune
Postby cougar » Fri Apr 15, 2016 3:37 pm
That was mildly entertaining. Reindexed the throttle lever and now the idle is too high even with the screw backed all the way out. I'm within a hundred RPM though. Turned the star wheel up a turn. Made a big difference on the smoke. Takes about 2 seconds to hit 30psi. Throttle is very responsive at cruise speed.
cougar
Re: Time to retune
Postby cougar » Mon May 30, 2016 12:15 pm
Did some more tuning. Boost up to 35 and less smoke. Haven't touched the timing yet.
cougar
