How do my stock intercooled 1991.5 injectors compare to 5x12
Postby Diesel » Mon Apr 25, 2016 8:40 am
I believe my stock injectors are tired. Lots of miles and starting to be a pain to cold start. Either way - I could use a fresh set of injectors. Do the stock 1991.5 intercooled trucks use a 6 hole injector? I'd like to go to a 5x12 as long as its the same spray angle. My stock injectors are 145 or 155 degrees? Thanks guys!
1991.5 D250 Intercooled A518
Diesel
Re: How do my stock intercooled 1991.5 injectors compare to 5x12
Postby spencerdiesel » Mon Apr 25, 2016 1:34 pm
An intercooled truck will have 6x.009 and 145 degree spray angle
H1C/18
Muffler delete
spencerdiesel
Postby RCCUMMINS89 » Thu Apr 28, 2016 8:34 pm
Factory i/c injectors flow 40lpm in air. 5x12, 145 angle, vco injetors flow 55. Therefore 5x12 flow 37% more than stock.
What are your goals? Auto or manual? What turbo? What current mods? Have gauges? How do you use the truck?
