He351cw solenoid
He351cw solenoid
Postby kyled19 » Fri Apr 29, 2016 3:42 pm
How do you power the he351 I know you just run 12v but to run it to both posts in the connector or does it need a ground? Is there a certain side the power goes to? Any help appreciated!!
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: He351cw solenoid
Postby kyled19 » Tue May 03, 2016 7:35 am
anyone?
kyled19
Postby 79Powerwagon » Tue May 03, 2016 10:34 am
I cut my solenoid apart and brazed the upper 4 holes shut.
Wastes at 22 psi, clamp line or add a inline regulator (boost elbow) if you want more.
79Powerwagon
Postby stuffy » Wed May 11, 2016 5:50 pm
Just run power to one and ground the other one. Probably put power either on a switch or tap into something that only has power when the key is on
92 w250
Silver Bullet, pump maxed, full manual 47re, 5x18s, Hungry Diesel piston pump
stuffy
Postby RCCUMMINS89 » Sat May 21, 2016 9:45 pm
Yep, run ground to one wire and positive to the other wire. Run it through a toggle switch. Off it will open at 20, with power, it'll open at 40.
Postby dbshelton » Sun Jul 09, 2017 3:25 pm
One wire is marked with a Blue-Colored Dot. Is that the positive wire or the ground wire?
dbshelton
Postby stuffy » Sun Jul 09, 2017 4:11 pm
I don't think it matters
92 w250
stuffy
Postby RCCUMMINS89 » Mon Jul 10, 2017 4:51 pm
It doesn't matter which wires you run the power/ground to.
Postby dbshelton » Tue Jul 11, 2017 4:26 am
Thanks for clearing this up.
dbshelton
