Master Power turbo
Master Power turbo
Postby GO OVRIT » Sat Dec 29, 2007 6:06 am
http://store.pdrdiesel.com/products/Mas ... 52-26.html
These are on sale, and looked like a good deal.
GO OVRIT
Re: Master Power turbo
Postby flashgordon » Sat Dec 29, 2007 8:56 am
GO OVRIT wrote:http://store.pdrdiesel.com/products/Master_Power_Turbo_1991_5_02_Dodge_Cummins-952-26.html
Well from the advertisement, it sound like a grate turbo to fit between the Hybrid HX35's and and a s300?.........
For those of you, that are good at understanding them there, air numbers????????
Is the above statement true?
Grate price YES...NO?
Flash
flashgordon
Postby gman07 » Sat Dec 29, 2007 9:09 am
1992.5 W250 pump tweaked, straight pipe, gauges, 3200 Gov. spring, AFC lever partially ground, timed at 1/8", Fuel pin ground, BHAF, HTT Stage IV H1C/E 60/12wg (ported), Transgo shift kit, KDP clothes-hangered, 202,000 miles - 36psi, 1250°
gman07
Postby flashgordon » Sat Dec 29, 2007 11:33 am
gman07 wrote:http://www.dieseltruckresource.com/dev/showthread.php?t=175270&highlight=Master+Power+Turbo
Thanks for the link :thumright:
Sound like they don't have a waste gate and explode or come apart a lot.
When that descusion was made thay were still on sale for $550.00............thougth about makeing a coment there that the price had been reduced........ but i never travel in the 2nt gen area of that sight.........so I wouldn't catch there coments any ways.
It would still be temping if i was in the market for a better turbo??????? then the Hx35??????????
Flash
flashgordon
Postby dpuckett » Sun Dec 30, 2007 8:39 pm
I called and talked to someone about them (not Mark, and not Harry). Said the late Pastor Bob had one on his truck, and liked it. You will need 350hp+ to get the most from it. I decided not to get one because I wanted something a little more proven, and I am nowhere near 350hp. I think if you didnt abuse it, it'd do ok.
Greenleaf and I did like the 4" outlet, with the 16cm housing. I think the 66mm inducer may be a little hard to get going.
Daniel
