Aspect ratio vs cubic centimeters
Re: Aspect ratio vs cubic centimeters
Postby 1STGENFARMBOY » Fri Nov 10, 2017 12:58 pm
It's really because your so tight you squeek when you walk. :lol:
I have been reading that the china turbo's are a lot better than when they first came out.
Postby cougar » Sat Nov 11, 2017 9:14 am
ellis93 wrote:@Cougar
Day3.....So far I'm not regretting the purchase or the machining of my 12cm exhaust housing. Over 200 miles and it sounds like a jet creeping down main street with the windows down. Spool time with this automatic trans is almost nothing,you can goose the throttle in neutral and get 4/5# easy.
The whole reason I'm fooling with this china brand turbo is because of all the hate they seem to get on the internet.....may of which are ancient.
We'll see....one way or another.
That sounds encouraging. Considering you have it on a 24V, I'd be curious how it would do on a 12V. Ignore the squeaking noise, it's the rusty gears in my head turning.
92 W250 HD 47RH with Compushift. Upgraded H1C to 60/60/16, modified fuel pin, DAP 7X.010 injectors, 4" DE exhaust.
01 2500 "the work truck".
cougar
Postby ellis93 » Sun Nov 12, 2017 12:14 pm
1STGENFARMBOY wrote:It's really because your so tight you squeek when you walk. :lol:
Consider this.....for 250$,it's not a bad deal. The fit and construction looks and feels great......no less cheap looking than some of the supposedly quality reman stuff I've looked at and installed. The compressor wheel looks better on it than the GDS 60 wheel I bought for the dodge lol
I gave 550$ (Traded out valve for value) for an actual hx40,used.
Postby ellis93 » Sun Nov 12, 2017 12:18 pm
Nearly 600 miles,not the first issue. I've eased up on it tho. The fuel money is no going far enough lol
I'll post a link to the one I bought.
Postby 1STGENFARMBOY » Mon Nov 13, 2017 10:03 am
I am hearing this from quite a few guys.
Postby ellis93 » Thu Nov 23, 2017 6:34 pm
Right at 1200 miles,no issues......
Postby PToombs » Sat Nov 25, 2017 6:16 pm
You must be driving the crap out of that truck! 600 miles in under 2 weeks!
Postby Remps » Sun Nov 26, 2017 12:05 am
Why no boost #'s yet, no boost gauge? :grin:
Postby ellis93 » Sun Nov 26, 2017 8:14 am
PToombs wrote:You must be driving the crap out of that truck! 600 miles in under 2 weeks!
Yes......lol,at very least I drive over 50 miles a day,that's just from the house to the shop and back.
Remps wrote:Why no boost #'s yet, no boost gauge? :grin:
Just driving normal,20# tops
Beating on it,I've seen nearly 50.......I like the head gasket intact,so I try hard not to do that.
It lights off pretty quickly,it's probably the one thing I haven't really paid much attention to.....at what rpm it's pushing boost.
