Scheid Diesel
Scheid Diesel
Postby cougar » Sat Mar 31, 2018 10:26 am
Any thoughts or comments on their Lightning100015 12MM 4000RPM VE Pump?
01 2500 "the work truck".
cougar
Re: Scheid Diesel
Postby RCCUMMINS89 » Thu Apr 12, 2018 5:49 pm
They put out a decent amount of fuel, but they remove the dynamic timing of the pump, by pinning it.
Re: Scheid Diesel
Postby Remps » Sun Apr 15, 2018 7:10 am
I thought they only pinned the 14, they pin the 12 as well?
Re: Scheid Diesel
Postby RCCUMMINS89 » Sun Apr 15, 2018 9:57 am
Yes.
Re: Scheid Diesel
Postby cougar » Fri Apr 20, 2018 10:53 am
I got one and had it installed at a local performance diesel shop. Apparently mine isn't pinned. It came without a KSB, so I asked them about it. They said to transfer my old one over to it. Works as advertised. And yes, it does put out a decent amount of fuel. Better throttle response and less turbo lag, but I think that is because the old IP was in sad shape. Normal driving and cruise are no different looking at boost and EGT numbers. The difference comes in when you mash the peddle. I'll need to change my boost gauge and maybe add water injection.
cougar
Re: Scheid Diesel
Postby RCCUMMINS89 » Fri Apr 20, 2018 11:00 am
They still put a ksb on it. However, how do you know your ksb is still changing timing?
Re: Scheid Diesel
Postby cougar » Sat Apr 21, 2018 8:34 am
By the change in engine sound when I jumper it to the battery.
cougar
Re: Scheid Diesel
Postby RCCUMMINS89 » Sun Apr 22, 2018 7:33 pm
Maybe they stopped doing all of them. I was told straight from them they do it on all maxed out pumps. Everyone I have personally seen is as well. What they do is not actually pin it, but they add so much shim that the piston can't really move.
