Cuz I haven't posted in 2 years.
Postby RCCUMMINS89 » Thu Apr 12, 2018 5:46 pm
643 corrected, 535 uncorrected, at 5k' elevation.
https://www.youtube.com/watch?v=rBoKX0e2Lzs
Re: Cuz I haven't posted in 2 years.
Postby DMan1198 » Fri Apr 13, 2018 9:42 am
That’s wicked man. Is that still with a single 62, or did you switch to compounds?
Postby RCCUMMINS89 » Fri Apr 13, 2018 4:41 pm
64.5sxe/73/.91
Postby Remps » Sun Apr 15, 2018 7:27 am
Impressive! I guess the little ve likes to breathe up top with a freer flowing 24v head and larger turbo. Any tq #'s? How is that turbo to DD? Makes me want a 64/73/.85 lol.
Postby RCCUMMINS89 » Sun Apr 15, 2018 12:57 pm
24 valve head is more efficient down low. in 4th it did 1600tq, corrected. That cam and head is what allows me to run a large t4.
Postby spencerdiesel » Sun Apr 15, 2018 3:42 pm
Highest I've seen or heard of a TWELVE mm........congratulations and props to you sir.
I'll inhibit my obscene number of questions now.
H1C/18
Muffler delete
spencerdiesel
Postby 79Powerwagon » Mon Apr 16, 2018 7:11 am
Nice numbers!!
Whats the general setup if you dont mind?
Must have scounged up some fuel somewhere to break that 500hp ceiling :/
79Powerwagon
Postby RCCUMMINS89 » Mon Apr 16, 2018 11:04 am
The extra fuel is from the THD 12mm ve pump. Historically, 260cc or so is max on a ve. We're getting 320 now, with mods. Still all Bosch parts (minus fuel pin and timing spacer).
Postby spencerdiesel » Mon Apr 16, 2018 6:49 pm
This is really really great. RC, Is there a minimum reccomended injector size that should be run to keep stress off the pump?
H1C/18
Muffler delete
spencerdiesel
Postby RCCUMMINS89 » Mon Apr 16, 2018 6:54 pm
I honestly wouldn't worry about running stock injectors. However 5x14/6x13 or larger, would be recommended... mainly because..... why run a higher flowing cc pump on small sticks? Defeats the purpose to some extent.
Postby spencerdiesel » Tue Apr 17, 2018 3:11 am
Makes sense, is the fuel delivery/cc curve similar to a 260cc pump in regards to rpm? Is the timing sweep set up different?
When will this pump be available and will there he limited production?
H1C/18
Muffler delete
spencerdiesel
Postby Remps » Tue Apr 17, 2018 7:17 am
Any bolt on pump parts for sale that increase fuel delivery, or is it all internal mods to get the extra 40-60 cc? What size injectors do you bench your pumps with?
Postby RCCUMMINS89 » Tue Apr 17, 2018 10:19 am
Internal. Std. .7mm p pump plates. Test injectors are nothing like engine injectors.
Postby Remps » Wed Apr 18, 2018 11:31 am
So if a stock maxed pump does 260ish cc on your pump stand, and a stock maxed pump does 300 cc on kta's pump stand/6x18 injectors, your pump on his stand and 6x18's would be somewhere around 360 cc?
Postby RCCUMMINS89 » Wed Apr 18, 2018 12:11 pm
370 cc is 100% of the possible fuel that a 12mm rotor and 3.2 cam plate can push/per 1000 strokes.
But yes, I would easily expect to do that with that large of an injector, that isn't proper to use to bench a pump.
