Cuz I haven't posted in 2 years.
Re: Cuz I haven't posted in 2 years.
Postby chicknnhead » Thu Apr 19, 2018 7:59 am
that's awesome....nice ramcharger
chicknnhead
Postby 79Powerwagon » Thu Apr 19, 2018 9:27 am
Was this the same 3.2 cam plate that appeared to measure out same as stock?
Or found one from another application?
79Powerwagon
Postby RCCUMMINS89 » Thu Apr 19, 2018 10:49 am
All of our cam plates measure 3.2
Postby 79Powerwagon » Thu Apr 19, 2018 11:21 am
Yes
Didnt know if by 3.2 you meant stock or other application since stock is typically called a 2.8
79Powerwagon
Postby Remps » Thu Apr 19, 2018 8:20 pm
What gov spring does it come with, are options available? Is the afc set up with a longer "slide pin" thingamajigger for more afc control? If not, is that optional? Also what rpm was your peak hp? :grin: Do all camplates actually measure 3.2?
Postby Remps » Fri Apr 20, 2018 6:11 am
I think BC's truck would be over 500 hp already with a lockup trans, 600 or close to it with this pump. The internal mods that you've done...would they be of benefit feeding a 14 mm head compared to a stock 12 mm pump?
Postby RCCUMMINS89 » Sun Apr 22, 2018 7:33 pm
Yes a 14mm will still move more than a 12.
Postby RCCUMMINS89 » Sun Apr 22, 2018 7:35 pm
Remps wrote:What gov spring does it come with, are options available? Is the afc set up with a longer "slide pin" thingamajigger for more afc control? If not, is that optional? Also what rpm was your peak hp? :grin: Do all camplates actually measure 3.2?
Can set them up however, afc wise. Same with gov spring, whichever.
Dyno peak was about 2200 rpm, but it held almost flat til I let off. At 3k or so. They waived trucks early on the dyno.
Postby spencerdiesel » Mon Apr 23, 2018 3:17 am
2200 revs for peak hp :shock:
My Lord no wonder the torque was so much!
H1C/18
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Muffler delete
spencerdiesel
Postby RCCUMMINS89 » Mon Apr 23, 2018 10:55 am
Well... it's a ve.... lol.
By design, a ve will always have its peak fueling come in at 1900 rpm. The best I've ever seen is it holds full fueling to about 2400, and then every pump starts to taper off. Minor on these pumps, but still tapers.
Postby spencerdiesel » Mon Apr 23, 2018 3:08 pm
So basically if your turbo setup isn't fully lit by 1900 with a ve you could say your not seeing max potential power?
Even on my wimp truck I know peak hp via butt dyno is immediately when the turbo lights fully, then it's steadily downhill from there.
In 1:1 mins lights at 2k
H1C/18
Muffler delete
spencerdiesel
Postby erroljon » Tue May 01, 2018 11:54 pm
That's impressive.
1988 Dodge Ram 150 Offroad Modification: Added Warn Winch and Toyo tires.
erroljon
Postby DMan1198 » Wed May 02, 2018 12:08 pm
spencerdiesel wrote:In 1:1 mins lights at 2k
It’s always been rather interesting to me how 5.9’s always seem to struggle with spooling turbos compared to a 6.7. I still don’t have a tach on The Roo Hunter. she definitely lights up earlier than jaeger, but jaeger lights an 76/83/.9 at around 1900rpm, while the secondary on The Roo Hunter measures 60/60/.7.
Postby spencerdiesel » Wed May 02, 2018 6:49 pm
I bet 40+ extra cubes helps spool a given turbo sooner, do the commonrail 5.9s not spool close to 6.7s either?
H1C/18
Muffler delete
spencerdiesel
Postby DMan1198 » Thu May 03, 2018 9:58 am
Eric had a 67/87/.9 on his 06 when he first put dual pumps, and 100% over injectors in that spooled like an 80/83 did on mine with stock fuel. About 2100rpm. That same 467 would spool around 17-1800rpm with good tuning on a 6.7.
