Cuz I haven't posted in 2 years.
Re: Cuz I haven't posted in 2 years.
Postby 79Powerwagon » Tue May 29, 2018 5:57 pm
Will there be pump parts sold for the DIYer or strictly reman pumps?
Mine is going to need a H/R sometime....if not a P :shock:
79Powerwagon
Postby laneends » Wed May 30, 2018 1:31 am
Wow, impressive numbers!! I guess I know where to get my next pump! I have a growing shopping list in addition to all the stuff I've already bought from you.
1990 D-250 with getrag 360: pyro, boost, volt, oil pressure, fuel pressure, and water temp gauges, hot screw, 366 gov spring, THD pin, M&H dynamic timing spacer, throttle linkage adjusted for full travel, 4" turbo back exhaust, THD's LPPLP, BHAF, south bend clutch. THD 5x13 comps, 362sxe, 3" crossover, pump to the head
laneends
