Help me spend my money!
Re: Help me spend my money!
Postby spencerdiesel » Thu Sep 27, 2018 6:52 pm
Lol that would be about my luck too
H1C/18
Fuel: THD 12 psi piston pump, THD fuel pin, 366 spring, fuel screw bottomed @ 3 turns, timing to the head/ >1/4”
Muffler delete
spencerdiesel
Postby Remps » Sat Sep 29, 2018 11:50 am
Is that a Hamilton head? Are you doing a cam swap as well?
Postby laneends » Sat Sep 29, 2018 5:27 pm
Yes and yes! Hamilton head, and a 188/220 cam. Just realized today the fuel heater will be going away...
1990 D-250 with getrag 360: pyro, boost, volt, oil pressure, fuel pressure, and water temp gauges, hot screw, 366 gov spring, THD pin, M&H dynamic timing spacer, throttle linkage adjusted for full travel, 4" turbo back exhaust, THD's LPPLP, BHAF, south bend clutch. THD 5x13 comps, 362sxe, 3" crossover, pump to the head
laneends
