Differences between IC and non IC H1C
Postby Jdk » Sun Dec 30, 2018 9:46 pm
I was wondering what the differences are between the H1c from both IC and non IC, I’ve been putting together parts to install a 7.3 PS IC on my truck(1990) and a Amsoil 4510 with 4” tubing CAI, but then I read the non IC air intake is only 3” as opposed to 4” on the IC trucks, is this true?
So far the differences I have found:
IC(big H1c?): 8 blade, 54mm compressor wheel
NON IC: 7 blade, 50mm compressor wheel
I was thinking about upgrading my compressor wheel to the 60mm, but the site I found a kit on lists that is is only compatible with Factory IC trucks: https://gillettdiesel.com/shop/Holset-H ... 60mm-CH-05
I plan on upgrading to a 62sxe at some point when i feel like dropping the money on a upgraded clutch, head studs, 4” exhaust and some honed marine 370s from THD so figured I’d future proof my intake and intercooler.
Thanks in advance
EDIT: Found in a post on a different forum regarding the differences:
H1C non IC - 50 mm inducer(small side) 83 mm exducer(large side) on the compressor, 70 mm inducer (big side) 60 mm exducer (small side) on the turbine 18 cm housing
H1C IC - 56 mm inducer, 83 mm exducer on the compressor, 70 mm inducer, 60 mm exducer on turbine 21 cm housing
WH1C - same as IC H1C, with a 12 cm wastegated housing
94-98 HX35 - 54 mm inducer, 83 mm exducer on the compressor, 70mm inducer, 60 mm exducer on turbine
98.5-02 HX35 - 7 blade 54 mm inducer, 78 mm exducer on compressor, 70 mm inducer, 60 mm exducer on turbine
‘90 W250 RCLB G360 Stock (for now)
‘96 2500 ECLB 2wd auto Stock
Jdk
Re: Differences between IC and non IC H1C
Postby Remps » Mon Dec 31, 2018 3:08 pm
Only difference between n/ic and ic h1c is 50mm/54mm compressor wheel, smaller intake on the baby h1c (the 50mm), and of course the 21cm turbine housing on the 91.5-92 trucks. There may be some rare 56mm later h1c's. Hx35 has a 56mm compressor, early 94 wh1c had a 54mm compressor, and a 12cm gated ex housing. 98-02 hy35 has the 54mm wheel and a single volute turbine housing, like a he341.
Postby Jdk » Mon Dec 31, 2018 5:42 pm
Thanks Remps.
guess I need to grab a 4” to 3” 45* reducer to make my intake work with the baby h1c.
Jdk
Postby DMan1198 » Wed Jan 02, 2019 12:55 pm
Actual turbine wheel measurements vary 2-3mm on inducer, and exducer for seemingly no reason. Of course that’s nothing useful that hasn’t already been mentioned, but I’ve measured a few over the years, and it’s just something I’ve noticed.
Hy35’s also only came on automatic equipped vp44 trucks. For some reason I want to say they only on the last few years of 2nd gens though.
Postby Remps » Wed Jan 02, 2019 7:28 pm
On the h1c's? Or the hx/hy?
Postby DMan1198 » Thu Jan 03, 2019 3:28 pm
H1c, hx35, hy35, he351cw, he351ve. All similar, but I have yet to measure 2 exactly the same.
