C series lift pump?
C series lift pump?
Postby Jdk » Sun Jan 06, 2019 10:44 am
I was going through some kits for low pressure high flor piston lift pumps, and I saw a pump with part number 4988748(THD’s kit) which is a 6ct pump, do these pumps work on our 6bt’s?
‘90 W250 RCLB G360 Stock (for now)
‘96 2500 ECLB 2wd auto Stock
Jdk
Re: C series lift pump?
Postby wilkyflex » Mon Feb 02, 2026 4:49 pm
did you find an answer yet?
The one I have is a HFP702 which is the right pump for low pressure and high volume. But mine is leaking and a new one costs $369. Ouch.
wilkyflex
