5x16’s and an he351?
Postby kyled19 » Wed Jan 16, 2019 8:07 pm
I have someone looking to get rid of some quality 5x16’s for a good price but I’m pretty sure it’s to much injector for my turbo. I have a stock he351 with a pretty much max pump, 3200 gov spring and dennyt stage 2 (I know i know I need to get a hungry diesel pin). The timing is bumped on my pump too but I can’t remember how much. What’s everyone’s opinion on those injectors with my setup? Are they going to be way to hot? Can I tune enough fuel out of it down low to make them work? Or should I just save up and buy 5x12’s? Forgot to mention they are 145 angle SAC. P.S. I would like to go to a billet wheel eventually. And maybe a compound set up with an s472 but that’s way down the road.
93 d350 extened cab dually dennyt stage 2, 3200 rpm gov spring, intake, 4 inch exhaust, he351cw, fass lift pump, and an a518. 4th gen seats
kyled19
Re: 5x16’s and an he351?
Postby Richie O » Thu Jan 17, 2019 6:28 pm
You could back the fuel screw out and be fine. I have 6x16s at 300 hp they just smoke all the time.
Postby Remps » Fri Jan 18, 2019 5:42 am
If you are planning on compounds down the road I'd get the 5x16 if I were you. I ran quality 5x18's and an h1c no problem, in fact, overall they ran cleaner than the 4x12-155 degree spray angle (4 hole 190's) that I pulled out. That was in a 93 as well. Just get a stiffer AFC spring, and re-adjust the pump and your right foot.
Postby kyled19 » Fri Jan 18, 2019 8:57 am
Awesome! Thanks for the info! Thats kinda what I figured but I just wanted to make sure. I will have to pick them up. Where would one purchase a stiffer afc spring?
kyled19
Postby Remps » Fri Jan 18, 2019 9:01 pm
I used a green/black AFC spring out of a n/ic pump that's a fair bit stiffer. The hungry diesel also has an aftermarket spring.
Postby monoblock » Mon Jul 08, 2019 11:04 am
Looking for a cheap fuel pin+spring upgrade ? Beware of the low price ones. Just read the reviews of this $60 pin+spring 'upgrade' !
https://www.amazon.com/dp/B0774TV58L
The Hungry Diesel (THD) new product seems a better choice even though it is way more $.
https://www.thehungrydiesel.com/THD-Fuel-Pin-THDpin.htm
monoblock
