Can you change gear ratio (and add LSD) on a D70u rear end?
Postby Begle1 » Mon Aug 17, 2020 5:21 pm
Nowadays I have some money and live on an island with no speed limit above 55 mph. There is a 1/4 mile dragstrip however.
I have a mind to go to a greater-reduction rear end and limited slip at the same time. I currently have the 3.07 D70u.
Instead of finding a whole new axle, would it be possible to bolt something like a 4.11 LSD ring and pinion into my D70u? I've heard that the 3.07 ratio can't work in a D70, but I've never heard about somebody trying to go the other way.
Anybody know if I have any options?
Re: Can you change gear ratio (and add LSD) on a D70u rear end?
Postby Philip » Tue Aug 18, 2020 6:40 am
To change the ratio in that axle would require quite a bit of machine work. The pinion is offset to the ride side about 5/8" for the larger pinion need for that ratio. The has been one person I know of that has regeared an axle to 3:54's. That was many years ago on TDR website.
If you could find a ring gear spacer you could do it. I am not sure if they are made anymore. Might call randy's ring and pinion. They would know if a spacer.
Postby Begle1 » Tue Aug 18, 2020 11:25 am
Thanks Philip!
Sounds like not worth doing. I'll call Randy's at some point just to see what they say regardless.
Postby Philip » Wed Aug 19, 2020 6:05 am
A ring gear spacer is the best option. I don't know if they make them for the 70's anymore.
