need help, twins and ve
Postby PToombs » Wed Jan 16, 2008 6:01 pm
Happy B- day CK! :bday: :jumpsmile:
Postby cummins king » Wed Jan 16, 2008 6:04 pm
thanks PT
a little update got the hot pipe done, wow lots of welding there
left to do
oil drains
and remote oil filter
and tubes from large to small turbo and to the intake
then im done
93 4X4 auto
cummins king
Postby cummins king » Thu Jan 17, 2008 4:29 pm
almost done
for anybody thats still intrested
93 4X4 auto
cummins king
Postby PToombs » Thu Jan 17, 2008 5:01 pm
Man, that's cool! :2cool: I like it up in the air where you can see it. Are you going to be able to close the hood? :oops:
:jumpsmile:
Postby ford69557ci » Thu Jan 17, 2008 5:49 pm
when i was test fitting for my twins i could close the hood with a s300 in the same position
ford69557ci
Postby cummins king » Thu Jan 17, 2008 6:51 pm
8) that would be funny if it didnt close :lol:
93 4X4 auto
cummins king
Postby cummins king » Thu Jan 17, 2008 6:53 pm
ya there 1/2 inch of room between the hood and the top turbo, its tight anybody know were you can get that hood thing that go from the front of the hood to the back
and one other thing the lip on the bottom turbo is like 3 inchec would it be a big deal if i cut it of and slid a 3 inch boot over it instead of finding a v band clamp and the right fitting for it
93 4X4 auto
cummins king
Postby TWorline » Thu Jan 17, 2008 7:01 pm
Instead of splitting your oil line from the existing location you could take the other plug out that is on top of the filter housing and run two seperate lines.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby cummins king » Thu Jan 17, 2008 7:03 pm
whats the difrence, its probaly not going to stay that way anyways because i have to make a remote filter system for the air filter, anybody know of a good 5 inch air filter
93 4X4 auto
cummins king
Postby SChandler » Thu Jan 17, 2008 7:04 pm
The bottom turbo is the low pressure turbo, IIRC, so you should be okay with a boot there. If you look at the photo of the engine at the bottom of the page http://www.piersdiesel.com/DodgeTwins.htm it looks like that one is using a boot. I wish I was getting twins for my birthday! :P
SChandler
Postby cummins king » Thu Jan 17, 2008 7:11 pm
ya i wish to, it want a bday pressent, it was noting but a pain and blood nuckels :?
93 4X4 auto
cummins king
Postby cummins king » Thu Jan 17, 2008 7:12 pm
i think your right they do use a boot, so am i know saves me from running aroud a junk yard looking for one
93 4X4 auto
cummins king
Postby KTA » Thu Jan 17, 2008 8:34 pm
Your hot pipe looks like 4". If it is you could benifit quite a bit from smaller piping. My Hx60 is not mounted parallel to the block, I cocked it over that way the air inlet would clear the oil filter, it looks like yours could to if you did it that way. Doing that also made it easier for me to get the 5" downpipe out between the frame and bellhousing.
Postby cummins king » Fri Jan 18, 2008 6:41 am
you have a 3 or 3.5 inch hot pipe
:worthless:
93 4X4 auto
cummins king
