porting
porting
Postby cummins king » Thu Jan 10, 2008 11:15 pm
anybody want to give me a quick crash cource on porting and polishing, and what type of tools you use
thanks
93 4X4 auto
cummins king
Postby DTanklage » Fri Jan 11, 2008 6:40 am
i use a dumore motor
series 35
they are as good as it gets
be careful - this thing will remove material like no tomorrow
http://www.dumorecorp.com/grinder.htm#10
kinda spendy but they are the best for porting
if all you are doing is a cummins head there is hardly any material to remove
you could just use a 1/4" air grinder (hard on the air compressor tho)
contact joe at mondellos for your arbors cartridge rolls and such
he is the man
http://www.mondello.com/Catalog/SA_Video.htm
leave the swirl affect in the intake port of you will lose power - no kiddin
most important area is from the valve seat 1/4" into the bowl
that and the guide area
supercharged engines do not see hp gains from porting like gas motors do
unfortunately
:evil:
DTanklage
Postby seeker1056 » Fri Jan 11, 2008 7:13 am
I use a makita long nose electric grinder and tree shaped grind stones as they produce a nice finish and remove material quickly. The grey stones are really aggressive and the pink stones leave a nice finish surface
The PDR site shows some good pix of a ported head although I would do considerably more work around the valve guide areas than they show.
For our purposes meaning pressurized flow, smoothing out the casting flash and corners and blending works a world of good
Larger passages are not necessarily what you are looking for but you are looking to equalize the sizing of the passages so there is less bottlenecking to the valve, especially at the valve guide areas
A five angle valve job would also make a huge difference.
On the exhaust side, port matching of the exhaust manifold it self should show a lot of benefit.
If you have never ported a head before, do a lot of research first - its an expensive "OOPS" when you break through the casting into the waterjacket
When we were doing race porting we always bought a junk head for the motor type to be used and removed the valves and got out a 1/4" drill and swiss cheezed the entire port. Just slicing a port in half does not give you a clear enough view.
This allows you to see exactly where the casting is thick and thin, and it shows where the most gains can be made as you open the port behind the valve and valve pocket.
Then you port this swiss cheezed port and when your happy you make cardboard templates of the entire port in various places.
These templates then become yuor guide in the good head ie you only grind till the template fits.
Even still with all of this information, it would take a book(s) to describe where and how much material to remove and why.
And then, no two heads or ports (different engines and layouts) are the same so then to really do it right you need a flow bench
And no matter how much you read it still takes a good eye as well as a "feel" for the work.
Do yoursellf a favour and get a good pair of anti-vibration gloves cuz by the time your done even one port your fingers will be numb which isnt a good thing longterm. Good motorcycle glove swill do in a pinch.
Its a terrible job at the best of times but it is also really rewarding if ya get it done n done right - good luck
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby DTanklage » Fri Jan 11, 2008 7:19 am
ps - porting is like welding - it is an art
just because someone has a tig machine does not mean they can heli arc
i suggest you get some cracked junk heads and practice A LOT before you start removing material from your head
there are water jackets in cyl heads too
DTanklage
Postby DTanklage » Fri Jan 11, 2008 7:25 am
opps, sorry, wrote this (*and a bunch more...lol) but didnt hit submit right away and didnt know that someone else already touched on these thoughts
stones?
i didnt know anyone still uses stones to port
do you finish with cartridge rolls or pink stone?
check out mondello's site, he has all sorts of bits n stuff
don
DTanklage
Postby cummins king » Fri Jan 11, 2008 7:28 am
thanks for the info, how long does it take to do a head proporly
93 4X4 auto
cummins king
Postby seeker1056 » Fri Jan 11, 2008 7:35 am
how long??? thats a relative term? Are you doing an allout port job or just a casting smooth job?
In my heyday once all of the prelim research was done and the templates made - I could do an entire port in about 50 minutes
then my hands needed a rest.
How long will it take you ?? no idea
Yes I use stones on cast iron they are faster than burrs - and those carbide burrs are dangerous in the extreme - especially if they grab and try to rip the grinder outa yur hands and especially so workin in aluminum - however a burr is all that will work in aluminum ;o(
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby DTanklage » Fri Jan 11, 2008 10:25 am
a dumore will spin a carbide 20,000 and there is not a iron cast that will slow it down
was suprised to see joe sell the makita on his site
templates are great
another big plus is to scribe out all your final sizes (at the openings) BEFORE you start the job
DTanklage
Postby seeker1056 » Fri Jan 11, 2008 10:49 am
dumore or makita - at 20,000 when that carbide grabs it walks that bit in a circle about a dozen times before u can get off the trigger
I have seen cast iron so work hardened that a carbide just bounced on it barely scratchin the surface.
I really liek the look of that dumore - I may look into buyin one if my makita burns down again someday, as in worn out.
;o)
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby DTanklage » Fri Jan 11, 2008 3:38 pm
you wont regret it
get the 35 series
and i am tellin ya - with a carbide it will take 3/8 deep swipes at alum
and spins so fast it doesnt dig in to cast iron
don
ps - they do not even have a trigger! (cuz they have so much torque they know they wont dig in) they have a toggle sw
for real...
DTanklage
Postby cummins king » Fri Jan 11, 2008 4:03 pm
maby seeker i will take you up on your somtime soon, one thing i wasnt blessed with was pacients
93 4X4 auto
cummins king
Postby DTanklage » Fri Jan 11, 2008 7:35 pm
like i said, it takes more than just patience...
"owning a heli acr machine does not make you a tig welder"
did you check out mondello's site?
he does list some kits for beginners
as in first time porters
and porting one of these things is a lot easier than doing a all out n/a motor
you could do it if you really wanted to
the practice suggestion is a good one
DTanklage
Postby cummins king » Fri Jan 11, 2008 7:37 pm
sorry i doin an all out motor is easyer, bolt this to that weld this, no real guess work
93 4X4 auto
cummins king
Postby DValentine » Mon Jan 14, 2008 8:38 pm
I can vouch for being a NOOB and trying to port a head. I found the water jacket in the number 6 exhaust port. Called PDR and ordered one of theirs....stage one....happy camper.
You can have my old one to play with if you want.
Dave
'93 w250 215k with a few mods.
DValentine
Postby ford69557ci » Mon Jan 14, 2008 8:44 pm
depends on how much you want to do on the time i my porting guy has like 12 hours on the in take and exuahst sides but thats with milling of the factory intake and tappin the heads for the new bolts
ford69557ci
