External Wastgates
External Wastgates
Postby CumminsPride » Thu Jan 17, 2008 2:35 pm
I am not finding much on external wastegates other than 50mm. Where can I find something for lets say 2 1/2" or 3" and reliable for 50psi??? I am building twins and mocking up a custom manifold to move the outlet forward and up slightly. Also trying to find an external gate to make tuning easier. I need the gate so I know what to build into the manifold and where.
On a bit of ponder I am considering building my own kind of similar to a exhaust brake. My concern is sealing the shaft that the gate will function on. Any thoughts here are much welcomed too.
Thanks for any advice.
Wade
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby cummins king » Thu Jan 17, 2008 4:04 pm
me i have been looking for a wast gate more months i cant find any, im going to see what will happen with out one
93 4X4 auto
cummins king
Postby ford69557ci » Thu Jan 17, 2008 5:55 pm
i have a 60mm turbonetics gate on my s 10 not sure if they still offer it i have had mine for 2 years.
ford69557ci
Postby cummins king » Thu Jan 17, 2008 7:09 pm
ya but is it any good for 50psi
93 4X4 auto
cummins king
Postby CumminsPride » Fri Jan 18, 2008 5:47 am
Then I'll just plan on fabbing one! What's the easiest way to seal the shaft through the pipe in a home made pack brake?
CumminsPride
Postby swank » Fri Jan 18, 2008 6:51 am
how good of a seal are you looking for?
truck
swank
Postby CumminsPride » Fri Jan 18, 2008 6:57 am
minimal suit. I don't want alot of mess.
CumminsPride
Postby swank » Fri Jan 18, 2008 7:43 am
i was just planning on having a decent fit between a brass bushing and a SS shaft and calling it good. it'll never really see any pressure(unless of course, you decided to put the brake plate on the back side of the shaft for some reason), so it doesn't even need THAT great of a fit.
truck
swank
Postby CumminsPride » Fri Jan 18, 2008 9:00 am
Never thought of it like that. Makes sense though. Thanks for the insight.
Wade
CumminsPride
