I got a good deal on the 14mm head studs so I picked them up and drilled and tapped the block. It is really easy to do.
I also heard that the 14mm studs pull the bores into hexagons so I am in the middle of making a torque plate. Here are some pics
The plate is not done yet, I still have to drill the holes and bore the center holes to size and make it so it fits on the dowel pins. It is 3" thick. Does anyone know the bore spacing on these engines?
I am making a bunch more stuff, I will have more updates soon!!!!!!!!![/img]
