fuel line questions
fuel line questions
Postby cummins king » Thu Jan 31, 2008 4:39 pm
on the unit that goes into the tank, that has the sending unit and the return line and the fuel line
okay now that you know what im talking about hopfully
that spesial clips that attaches to the fuel in and fuel out, can they be switched around? my dad got over zelous on the return line and broke it so i want to switch it is it the same size?
i tryed but dinner was calling so i left it, but it didnt seem to want to go
93 4X4 auto
cummins king
Re: fuel line questions
Postby flashgordon » Thu Jan 31, 2008 5:01 pm
cummins king wrote:on the unit that goes into the tank, that has the sending unit and the return line and the fuel line
I'm sure the feed and return are different sizes
Why not get a bolk head conector and install a much larger pick-up tube............in the tank unit...........while your in there ;)
flashgordon
Postby PToombs » Thu Jan 31, 2008 5:11 pm
They might be the same, I'm not sure. I picked up a few when I was in the junkyard from a gasser, those were different. I had the sender out, and can't remember. :oops: I might go with a bulkhead and a 1/2 inch line when I have the cab off. It'll be right there. ;)
Postby ford69557ci » Thu Jan 31, 2008 6:40 pm
yeah if you are goin to be runnin twins and all that then i would go ahead and upgrade the lines while your in there
ford69557ci
Postby cummins king » Fri Feb 01, 2008 7:05 am
duds why do you think i pulled the thing apart, just to look at it lol
of course i put the half inch feed in
but im putting it back together and the old reurn we broke so i want to put the old return on were the old fuel line went
93 4X4 auto
cummins king
