by ryan10 » Sun Feb 10, 2008 5:17 pm
Hey guys, im trying to get around if not over 350 horse and 700 ft lbs.
So far, this is what i have: the truck is a 93 4x4.
the mods are: suncoast tranny, fuel screw maxed, pump tweaked, bully dog injectors. (does anyone know the stats on these injectors, ive looked everywhere but cant find a definite answer. how do they compare to PODs?)
bully dog fuel pin, 14cm housing, and water meth.
I just ordered my 3200 spring, it should be here soon. while im in the pump, im going to grind the AFC foot.
A piston pump is also coming soon, as it deffidently needs it at WOT.
The turbo is stock. what would you recommend for an upgrade? i dont have a ton of money to spend, so what is something affordable?
What else needs to be done to reach my goal? bigger injectors? what would you recommend?
thanks.
1993 w350 6" lift, 35" all terrains. fuel screw in as far as it will go, pump mods, bully dog injectors, bullydog fuel pin, 14cm wastegated housing, water/meth injection. Ground AFC foot, 3200 spring
soon to come: turbo upgrade.
