when do you need heavier int vlv springs?
Postby DTanklage » Sun Feb 17, 2008 9:43 am
with the stockers on the intakes (and 60's on the ex) i have been to 3200 rpm and 50 psi boost
when do you need to install heavier intake valve springs?
don
DTanklage
Postby DTanklage » Sun Feb 17, 2008 9:44 am
ps - rpm is not going to go any higher with this motor but boost will
only another 10 psi tho
think i am at the stock springs limit now or do you think i can get away with another 10 psi???
DTanklage
Postby boostedve » Sun Feb 17, 2008 10:43 am
i have been told 3600 to 4000 rpm but you should do both the intake and the ex. with my truck i have been 3800 with stock springs a few times with no prob yet.. im not to sure about the keepers and retainers..
boost on the other hand your prob at your max with it i would be lookin for some head studs...
boost..
FOR SALE 1991 dodge d350 hx40 2nd gen intercooler, few pump mods, 366 spring, no afc, timing bump,pistion lift pump, 5" down pipe, bhaf, old smokey fuel pin, boost, pyro, tach gauges 14.10 @96mph 310hp, pm for pics and info..
boostedve
Postby PToombs » Sun Feb 17, 2008 10:47 am
Mark at PDR told me if you do 3200 or more regularly, 60# on all of them.
Postby DTanklage » Mon Feb 18, 2008 2:15 am
did he say why?
3 grand really isnt a lot of rpm
DTanklage
Postby cummins king » Mon Feb 18, 2008 7:02 am
probaly just to sell them, but if your doing the head you might as well throw them in, then you have some assurance
93 4X4 auto
cummins king
Postby DTanklage » Mon Feb 18, 2008 9:26 am
cummins king wrote:
probaly just to sell them...
thats what i was thinking too...
increased seat pressure does more than just 'sound cool'. it also wears everything out quicker (except the seats, IF valve float was occuring) and it decreases effeciency (takes power)
DTanklage
Postby PToombs » Mon Feb 18, 2008 6:21 pm
Well, I'd rather spend $110 on springs than $500 on a new head, and pistons, rods, new turbo, and what ever else gets f'ed up when the piston and valve meet at high speed. ;)
Postby TWorline » Mon Feb 18, 2008 6:58 pm
I have heard that with high boost pressure the valves can hang open at high rpm especially if the stock springs are getting weaker due to high mileage.
Tim Worline
http://www.CoolerTubz.com/
TWorline
