With the intercooler install that is.
Parts: $700, including lots of extra parts and the grille update.
Labor: xxx.xx hours...too many to count
Max EGTs 0-75 run before: 1300-1350
Max EGTs 0-100 run before: Who knows, would have to let out and try again, usually took several tries because of temps
Max boost before: WG 41lbs, non-WG 47lbs
Max EGTs 0-75 run now: 1050 or so
Max EGTs 0-100 run now: a whopping 1150 when I looked down at 98mph!!!
Max boost now: A very handleable 32lbs, much better than 47!!!
All in all, Im very pleased! Spool up is still good, and I like the floor it as fast as I want without worrying about temps...but thatll change when I play with the pump again.
