Additional Crankcase Venting
Postby bgilbert » Tue Mar 11, 2008 7:05 pm
Looking to add some additional crankcase venting on my 91.5. On my 89 I have a nice $50 oil fill and crankcase breather/two in one unit on the timing cover. I'd like to save some money on that right now, plus I don't get through Indy anymore to stop in at the blue C where I would just save time and hassle and spend some money. I'm not an ebayer, or I could wait and wait on a 2nd gen 24 valve breather. I'm pretty sure I've seen some pulling trucks with bungs of some sort welded to the top of 2-3 of their valve covers, then hose routed down the side of the engine. I'm thinking about doing this, until I've learned the valve covers are aluminum and you can't weld steel fittings to aluminum :evil: . Nobody in town has any aluminum fittings, let alone a weld in bung.
What's a guy to do? After installing the Pro52 on my auto truck, the 91.5, and taking a spin, oh and after changing my underwear, I seen where I blew some oil out the rear of the tappet cover. Would I lose a bunch of oil with an aluminum fitting on top of one or two valve covers? Any other ideas?
Bill Gilbert
bgilbert
Postby cummins king » Tue Mar 11, 2008 7:31 pm
put a fram filter on the oil filler
93 4X4 auto
cummins king
Postby CumminsPride » Tue Mar 11, 2008 7:35 pm
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby apwatson50 » Wed Mar 12, 2008 6:06 am
How about doing this, i'm thinking about adding one.
http://www.dieseltruckresource.com/dev/ ... cover+vent
92 Cummins, 4x4, 270K miles
apwatson50
Postby swank » Wed Mar 12, 2008 9:43 am
a bulkhead type fitting might work? just drill a hole and bolt it on. not sure if i've seen bulkheads that big that weren't plastic, but i'm sure they're out there.
truck
swank
Postby bgilbert » Wed Mar 12, 2008 3:37 pm
CP, good lord, $60+$17 shipping :shock: :shock: . I happen to have a very good medium duty junkyard locally and there are just dozens of B series valve covers laying around, probly could pick one up no charge. I have a few laying around myself if I screw one up.
AP, I'll have to look into something at Autozone.
CK, I don't like the looks of the filter on the oil fill.
Swank, I never thought of the bulkhead idea. I'm good at plumbing fittings, I might just do that. With the long male/male bulkhead, one would have to cut it off inside the valve cover to fit, not a problem. I only wonder if it would splash oil out real bad with no filter or baffle..?
bgilbert
Postby PToombs » Wed Mar 12, 2008 6:19 pm
If you use a large enough diameter fitting, the air flow will be slower than a small one. More oil should drop out. ;)
Or, run it up higher before going down.
Postby TWorline » Wed Mar 12, 2008 6:29 pm
Bill at work we put one of the push in gromets in the #6 valve cover and stuck a PCV valve in it with a tube hanging down the side of the block on one of our Rowcats.
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby DTanklage » Wed Mar 12, 2008 10:10 pm
bill, just do what josh did and get some of those ag valve covers
they have the breathers built in
this is what his motor looks like with em on:
that what it looked like
hes got the head off of it right now
some about getting the injector bosses remachined so he can put john deer 466 injectors in a 5.9
dual feed 5x35's
lol
that boys on a mission
DTanklage
Postby KTA » Thu Mar 13, 2008 5:18 am
Got a Cummins PN for those valve covers?
Postby JAyers » Thu Mar 13, 2008 7:51 am
Yes but its actually a case PN. Im pretty sure they arent made by cummins. Ill get it when i get home, im at college right now.
93 W250...balanced, ported, and fresh. Equipped with 14mm h/r, A1000 supply, Hamitons 188/220, T4 stainless manifold, s360/68/.91ar - s475/74/1.1ar twins, and Kennys dd clutch.
JAyers
Postby bgilbert » Thu Mar 13, 2008 3:28 pm
Tank, yeah I'm glad you brought those up. There was a big post about them WITH all the part numbers on TDR awhile back.. well maybe a year ago. I'm no longer a member there, and can't do an archive search, or I'd look them up. If I remember right they weren't cheap. I would be interested in part numbers Josh when you get to them.
Or PETE, how bout you look them up???!!!
bgilbert
Postby PToombs » Thu Mar 13, 2008 3:48 pm
Ok, but I want an extra $2 to babysit! ;) We all told you not to give up the subscription, but did you listen? Nooooo! :roll:
Postby bgilbert » Thu Mar 13, 2008 5:27 pm
Beat ya to it Pete. Here is a link from compD: http://www.competitiondiesel.com/forums ... t=breather
I figured I'd find them over there no problem. Pricey!! Pete get to work on them, remember J first, get back to me, please!!? :D :D
bgilbert
Case IH p/n's
Postby JAyers » Thu Mar 13, 2008 5:42 pm
Heres the list of part numbers, the only problem is ive got two numbers that have valve cover wrote next to them. Ive got a pretty good idea which one is right. lol I would go back to TDR but my subscription has also ran out. This is the quanity you will need for one double valve cover w/ one breather
#2830784 double valve cover w/ breather
#2852032 alternate part # if the one above isnt correct but i think its just a single valve cover.
#2852531 Breather
#2852028 Breather gasket
3 #899110 - alt #4899092 Breather screws, they are both diff threads. I used the first P/N.
These covers use a different bolt with a nice isolator to hold down the cover. Some people just use a washer with the stock bolt but I went ahead and went with the different bolt and isolator. I got tired of replacing rubber orings.
2 #4895360 Rubber isolater
2 #4895214 Valve cover bolt
JAyers
