hassy21 wrote:I am really interested in getting a hx40 instead of a hx35 just for more boost and lower egt's. What are the downfalls to them? Will I have to put head studs in or replace the head gasket? What kind of boost will it pull with what I have right now or for now? Where can I get an adapter to fit the hx40 on the exhaust manifold? Not many machine shops that I trust around here.
cummins king wrote:an hx40 will bolt right up to the exhaust manifold, the down side is they can over boost and explode at 50psi, with stock injectors and a 1/ timing you can it 40psi, so retorque the head but you wont need studs or head yet,
hx40 exhaust housing (16 gated) be adapted to an hx35 hybrid?
Philip wrote:hx40 exhaust housing (16 gated) be adapted to an hx35 hybrid?
You would need an HX40 exhaust wheel and housing. Then you would have a HX40. The center section is the same for a HX35/40.
The Super HX40 has some oiling mods that a standard HX40 doesn't.
