How much water to run? McMaster Carr nozzles?
Postby Begle1 » Sun Apr 06, 2008 11:16 am
Somebody suggested McMaster-Carr nozzles instead of designated-"Water Injection" nozzles.
They have various kinds of nozzles under "Misting & High-Pressure Spray Nozzles"; "standard misting nozzles" and "fogging nozzles" are what sound relevant.
"Misting" nozzles are $3.81 a piece in brass.
So I'm thinking, those nozzles with three solenoid valves;;;
Solenoid 1: 1 5 GPH nozzle.
Solenoid 2: 1 10 GPH nozzle.
Solenoid 3: 1 5 GPH nozzle and 1 10 GPH nozzle.
That would let me run the following progression, an increase of around 300 mL/ min per stage:
Stage 1: 315 mL/ min @100 PSI
Stage 2: 630 mL/ min @100 PSI
Stage 1+2: 945 mL/ min @100 PSI
Stage 3+1: 1260 mL/ min @100 PSI
Stage 3+2: 1575 mL/ min @100 PSI
Stage 3+2+1: 1890 mL/ min @100 PSI
Now, "fogging" nozzles are $22.14 a piece, which happens to be the same price that most designated "water injection" nozzles go for... Think that'd mean that the Cooling Mist and Snow nozzles are "foggers" instead of "misters"??
If I go with the fogging nozzles, they decide to jump in size from 12.6 GPH to 26.4 GPH @100 PSI...
So, the mild route;;;
Solenoid 1: 1 3.5 GPH nozzle
Solenoid 2: 1 6.6 GPH nozzle
Solenoid 3: 1 12.60 GPH nozzle
Then I could run the following progression:
Stage 1: 220 mL/ min @100 PSI
Stage 2: 420 mL/ min @100 PSI
Stage 2+1: 640 mL/ min @100 PSI
Stage 3: 800 mL/ min @100 PSI
Stage 3+1: 1020 mL/ min @100 PSI
Stage 3+2: 1220 mL/ min @100 PSI
Stage 3+2+1: 1440 mL/ min @100 PSI
So that would be a progression of about 200 mL/ min between stages.
And then the wild route;;;
Solenoid 1: 1 6.6 GPH nozzle
Solenoid 2: 1 12.6 GPH nozzle
Solenoid 3: 1 26.4 GPH nozzle
That would let me progress about 400 mL/ min between stages
Stage 1: 420 mL/ min @100 PSI
Stage 2: 800 mL/ min @100 PSI
Stage 1+2: 1220 mL/ min @100 PSI
Stage 3: 1670 mL/ min @100 PSI
Stage 3+1: 2090 mL/ min @100 PSI
Stage 3+2: 2470 mL/ min @100 PSI
Stage 3+2+1: 2890 mL/ min @100 PSI
I keep hearing reports from guys (Tank and David) saying that 1300 mL/ min doesn't even bog down an idling engine... That makes me think that 2890 mL/ min would not be overkill on a non-intercooled truck at 3000 RPM, 40 PSI and !@#$ degrees EGT... How much do you think I have to have to get away with 3/4 a gallon a minute?
Assuming that a McMaster-Carr mL/ min is equal to a Snow or Cooling Mist mL/ min, of course...
What do you guys think?
Postby Fnschlaud4620 » Sun Apr 06, 2008 11:36 am
What you are trying to accomplish by adding water injection is cooling of the intake charge air, not adding water to the engine.
With that in mind a higher presser getting sprayed through an orphis has more ability to asorbe more heat, do to thermo laws
That is why the pull trucks dont bother with an intercooler and run 600+ psi through a .003-.010 jet.
I have read about guys running a .003 jet on # 1 & 6. On 2 & 3, and 4 & 5 share a .005 jet and a .005 as close to the turbo as possiable after the comp wheel. This is at 600 psi though.
how is it done, a snowplow 12v electric pump and hobs switches, use machining water based cutting fluid as lube for the pump. Then you are serious.
Fnschlaud4620
Postby cummins king » Sun Apr 06, 2008 2:20 pm
haisly has a kit that is supost to make alot of pressure
but if pressure is the key then why not get a belt driven pump and ram 20000 psi of water into the intake ;)
93 4X4 auto
cummins king
Postby Fnschlaud4620 » Sun Apr 06, 2008 2:28 pm
20000 psi is the same amount of pressure used in a water jet cutter, it would be unsafe and blow a hole through the other side.
Fnschlaud4620
Postby Begle1 » Sun Apr 06, 2008 2:40 pm
Haisley has a belt driven and an electric driven kit, for $2500 and $1600 respectively. Used on trucks running four to five times as much horsepower as I'm ever going to sniff, with two to three times as much boost pressure. And 1000-2000 more RPM. With a lot more flow rate.
I wouldn't mind hearing more about an easy to install pump that can give me 300-600 PSI, but I feel that's a tad out of the current price (and performance) range...
Is there a point where any increase in flow rate at 150-220 PSI becomes worthless? Is that point before or after 3000 mL/ min?
Postby Fnschlaud4620 » Sun Apr 06, 2008 3:49 pm
here is some thing kinda like what I will be using. It has its own resivor for water and is less than 300.00. You could piece together a mean BIG POWER water injections kit for the same price as a snow kit.
http://cgi.ebay.com/MONARCH-12V-DC-HYDRAULIC-PUMP-SINGLE-ACTING_W0QQitemZ160226433393QQihZ006QQcategoryZ41484QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Fnschlaud4620
Postby Begle1 » Sun Apr 06, 2008 4:01 pm
Ooo, that is nice. You'd put a bypass regulator on it to keep things at your 500-600 PSI? If it could move 1.25 gallons per minute under full load, and it's adjustable up to 3000 PSI, it sure seems to me like it could atomize quite a bit at 500 PSI... Almost like I'd want it's baby brother instead.
How expensive or hard to find is machining-water cutting fluid?
I wonder what the amp draw on that baby is. Especially if you were putting it through solenoids instead of running it off a PWM, you'd be bypassing craploads of water.
How much greater cooling affect is there with 500 PSI as oposed to 150 PSI?
What kind of solenoids would you have to use for 500 PSI though? I have a feeling those would be more than the $40 for 150 PSI ones most guys run... I guess nitrous solenoids are around twice that if you get a good deal?
Postby Fnschlaud4620 » Sun Apr 06, 2008 4:16 pm
You dont need a bypass regulator, all you would have to do is adjust the pressure releif valve or put in a weaker spring untill you get in the 5-700 psi range.
then you can run it in stages, no PWM necessary, just make a log manifold supply, and how ever many stages you want.
stage one- one NAPA hobbs switch turns on, one solenoid supplys water to a jet, or jets, however you design, say it turns on at 10psi
stage 2 repet of stage one but turns on at 20 psi and can have bigger jets
Stage 3 turns on at 30 psi boost, or 40 what ever you want
Stage...............
the only other thing I am aware of is you must include check valves in the design so water doesn't fill the engine if you are parket on a downward angle.
http://cgi.ebay.com/SPINDKOOL-35-CNC-BI ... dZViewItem
cutting fluid, just a water based lube for the pump. mix at 15:1[url][/url]
Fnschlaud4620
Postby Begle1 » Sun Apr 06, 2008 4:24 pm
I don't see why you'd need a check valve if you were using default-off solenoids? Not like check valves a big deal...
Now you have me looking a little hydraulic pumps... What do I want, 1 GPM at 500 PSI?
Postby Fnschlaud4620 » Sun Apr 06, 2008 4:28 pm
I would say athat 1 gal/ min @ 500 would be good.
I saw one setup that has a 350 chevy starter modified to a couple to a small pump.
Fnschlaud4620
Postby Begle1 » Sun Apr 06, 2008 4:30 pm
Unless it was a kit, I don't see myself turning a Chevy starter into a hydraulic pump... My fabrication skills are pretty much maxed out at drilling holes in metal.
Who are some big companies that make hydraulic pumps? I'm trying to find a catalog with some GPH/ PSI curves so I can see what kind of pumps to look for...
Postby Fnschlaud4620 » Sun Apr 06, 2008 4:38 pm
Fnschlaud4620
Postby Begle1 » Sun Apr 06, 2008 4:52 pm
That one's too much, though... And it comes with one of those pneumatic atomizer nozzles...
I wonder what Harbor Freight's got...
Postby Begle1 » Sun Apr 06, 2008 5:05 pm
How about this one?
http://cgi.ebay.com/Hydraulic-12-Volt-D ... dZViewItem
If there are used pumps that put out 3 GPM at 2500 PSI for under $200, there have to be 1 GPM at 500 PSI ones out there for cheap too...
Postby Begle1 » Sun Apr 06, 2008 5:12 pm
And, you know, I don't have air conditioning...
And pulley-driven pumps are cheaper than dirt used...
