Well I finally got around to turning up the pump, now I have a few questions. Here are the specs on the truck as of right now:
-90 W250 Non Ic'd, 5spd, Welded front and rear, 40" michelin XL's
-Holset HX35 - 12 From a gyrotrac, waste gate wired shut, as the actuator bracket is right where the oil drain is on a truck setup.
-Pump turned up 3 1/8 turns (right to the point of runaway)
-Pump pushed to the head
-Starwheel about stock maybe a little above
-Fuel pin turned to max
-T27 smoke screw ALL the way up.
-Max and Min screws all the way out
-Stock 3" crush bent exhaust with muffler (I know, I know this is going soon)
Now it will spin the HEAVY 40's in second gear from a roll, chirp them into 3rd, hit 1500+ egt in 3rd gear under moderate throttle, and hit 45psi under full throttle.
I live at approx 2700ft ASL.
My Questions:
-Is the HX35-12 gonna live at 45psi or will I need to rig up that waste gate?
-How are you guys getting 4 plus turns without running away?
