cam timing
cam timing
Postby c12h26 » Tue Apr 15, 2008 6:24 pm
Has anyone ever advanced the cam timing on a 6bt like they do on the 855 cummins
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby KTA » Tue Apr 15, 2008 7:48 pm
You can time the cam wherever you so desire as long as you have enough piston to valve clearance.
Re: cam timing
Postby mhuppertz » Thu Apr 17, 2008 6:28 pm
c12h26 wrote:Has anyone ever advanced the cam timing on a 6bt like they do on the 855 cummins
Just remember that advancing the cam timing gives you more low rpm power but kills the top.
Retarding sacrifices low end torque for high end HP.
Unless somebody has done some dyno test and tune, I would just degree the cam to make sure it's timed the way the factory intended. I know in the gasser world, cam timing can vary, so it's always a good idea to check it while the motor is apart.
mhuppertz
Postby Begle1 » Thu Apr 17, 2008 9:10 pm
Advancing cam timing has an opposite affect as advancing pump timing?
Because, for pump timing, advancing gives you top-end at the expense of bottom end...
Postby mhuppertz » Thu Apr 17, 2008 10:19 pm
Begle1 wrote:Advancing cam timing has an opposite affect as advancing pump timing?
That's correct. I always remembered it because cam timing was the opposite of ignition timing, same as pump timing.
mhuppertz
Postby 1991cummins » Thu Apr 24, 2008 2:34 pm
on this subject, ive had alot of people tell me i should advance my pum timing.
but i just dont understand what exactly it would do for me.
any recomendations?
1991cummins
Postby 1991cummins » Thu Apr 24, 2008 2:35 pm
any recomendations?
1991cummins
Postby 2muchtq » Sat Apr 26, 2008 7:49 pm
So you advance the heck outta your pump timing to get high rpm power.
You then lose your bottom end... SO advance your cam to get your low end power back.....
2muchtq
