I'm brand new to having a waste gated turbo on my truck. It is a Super 40 with a 16 cm gated housing. The original waste gate actuator would not work in my application. I pulled the mount and actuator off of a stock 24 valve turbo. When I acclerate from a start, or from 0 boost, in 3rd, 4th, and 5th gear I can achieve 33 psi of boost. I did notice hooked to the trailer when the truck and trailer was already rolling along, and the power was rolled on for a hill, and the throttle went to WOT most of the time the boost would only read about 25 psi.
I don't know when the gate opens. I'm going to try and check this week. Why does it do this? Is this normal? Should it go to 33 psi whenever it gets WOT and enough load? I never have experianced this before.
Michael
