tranny
tranny
Postby 89silverbullet » Sun May 04, 2008 1:20 am
I have a guy that can get me the transmission, bell housing, pedals, pretty much everything I need to make my truck a 5-speed. A. will i need any floor mods? B. is $550 for it all worth it? P.S. i will try to talk price down a little ;)
1989 d250 muffler delete diaphram turned, fuel screw turned, the lowes special intake
89silverbullet
Postby Hot Dawg » Sun May 04, 2008 2:46 am
Is it a Gutbag or a NV4500??? Either way I would do it!
I paid $1000 for a NV4500 and all the fixin's. ;-)
93 W250 = 180k, pump timed and tweaked, PODs, HX35/40 with 12cm, Denny T power pin, 366 spring, 4" exhaust, shadetree intake.
Hot Dawg
Postby PToombs » Sun May 04, 2008 7:45 am
A decent used Getrag is worth that much! :shock:
Postby cummins king » Sun May 04, 2008 10:15 am
if you dont want it i will take it, by a518 isnt going to hold much longer
93 4X4 auto
cummins king
Postby 89silverbullet » Sun May 04, 2008 10:00 pm
its a getrag 8) but will i need a bigger transmission hump?
89silverbullet
Postby Philip » Mon May 05, 2008 5:38 am
You will need the floor section from a stick shift truck. The auto's in 2WD had a different floor pan than a stick. 4X4's had th same floor pans it didn't matter if they were stick or auto.
Look in the body sectioon for this site. PTombs is doing a cab swap. His donor cab was an auto truck. He swaped the floor pan from his old cab. He has pic's.
Postby PToombs » Mon May 05, 2008 4:18 pm
And some day I might get my ass off this computer and go work on it! ;)
Postby 89silverbullet » Mon May 05, 2008 11:27 pm
well ptooms is it a weekend project or a pain in my !#@ :;-|:
89silverbullet
Postby PToombs » Tue May 06, 2008 5:00 pm
Depends on where you cut it. I think in my pics I show where to cut it. I tried to cut it large, then cut down to fit. I had to pull most of the dash, (which I was going to do later, not now) and pull the heater to access where I wanted to cut. If you cut (in the front) just below the pinch welded seam (on the hump you are using), it will fit good.
Look thru the pics in my cab swap thread, and if you have more questions, fire away.
Oh, I didn't answer the time question. :oops: It can be done in a weekend, if you don't screw off much. I think I had about 6 hours in all cutting the humps out and fitting my hump to the donor cab.
This isn't counting the dash and heater BS.
