exhaust housing
exhaust housing
Postby bradshaw106 » Thu May 08, 2008 6:11 pm
my buddies has his old exhaust housing of his 98 dodge. hey put a banks on. will that housing work on my 92?
bradshaw106
Postby Begle1 » Thu May 08, 2008 6:22 pm
Yes, and it will work very well.
Gotta move the downpipe back and plumb in the wastegate to your boost gauge.
Postby bradshaw106 » Fri May 09, 2008 3:14 am
sweet, what is it that i could expect from the swap? i am new to the 1st gen. im hoping to pick up my first truck tomorrow. also i don't think i have a boost gauge. the truck is stock. do i just plumb it in the outlet side of the compressor? thanks for the help
bradshaw106
Postby GO OVRIT » Fri May 09, 2008 3:40 am
The easiest place to hook it up is on the side of the intake midway. There's a plug you can replace with a fitting and run from there to the wastegate actuator.
GO OVRIT
Postby bradshaw106 » Fri May 09, 2008 3:46 am
i have been doing a little research and for what i can tell the housing is a 12cm. some say to small some say go for it. came of a 98 with an auto.
what do you think. i do know that going from a 21cm to a 12cm must be a huge difference.
bradshaw106
Postby CumminsPride » Fri May 09, 2008 4:17 am
It should be fine. But before you play with the pump, get a pyro.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby nooblet » Fri May 09, 2008 9:54 am
bradshaw106 wrote:i have been doing a little research and for what i can tell the housing is a 12cm. some say to small some say go for it. came of a 98 with an auto.
Its really helpful when asking these questions to fill out your signature with information on your truck. If you have an auto, thats pretty small, but if you have a manual it will work good.
Chris
nooblet
Postby bradshaw106 » Sat May 10, 2008 5:19 pm
good news i checked his housing it is a 16cm!!
92 4wd 180k auto, 366 spring, turned fuel pin, loaded
first diesel!
bradshaw106
Postby CumminsPride » Sun May 11, 2008 5:34 am
Bolt on and enjoy then. I will say though that is not a stock housing from any 98.
CumminsPride
