Quenching Damage
Quenching Damage
Postby Begle1 » Fri May 09, 2008 8:56 pm
So, what's likely to happen when you're running full bore and seeing 1200-1400 degrees of EGT when one of your 1/2" water lines pops loose and quenches the air side of your engine compartment with a gallon?
Postby GO OVRIT » Sat May 10, 2008 3:45 am
I bet it was enough steam to make the truck dissapear. :shock: Did anythink crack?
GO OVRIT
Postby Begle1 » Sat May 10, 2008 7:42 am
It hasn't actually happened yet, I'd imagine that it'd stand a pretty good chance of cracking the manifold at least.
I have my solenoids mounted on the heater lines, so this was something I thought of after I blew a piece of hose out of a ferrule during compression testing...
