Big old bottom Turbo
Postby VEfreak » Mon May 26, 2008 6:53 pm
Hey, I'm gonna run a twin setup on my IC 91.5, and i was wondering what real good options are for a bottom turbo. I know the HT3B is easy and classic, but what else is there. I was also thinkin maybe an HC5A, and i saw an HT80 but i think that is probably to freakin redunkulous. The goal is 80 psi of boost. And anything that can be salvage from heavy equipement is a plus. All opinions are appreciated. And do you think an HE341 off a 3rd gen would make a good top turbo? I've heard the spool faster and run cooler than an hx35/40 hybrid.
VEfreak
Postby cummins king » Mon May 26, 2008 7:32 pm
i like my hx40 top and my ht60 for bottom, but if i could of found it i would of went with an hx60
93 4X4 auto
cummins king
Postby VEfreak » Mon May 26, 2008 7:41 pm
why an hx60 instead of an ht60? Beefier or more boost or better design?
Oh, and the s-300 with the 67mm turbine and 56mm compressor wheel aint worth a turd, right?
VEfreak
Postby VEfreak » Mon May 26, 2008 8:09 pm
If I pair a K31 with the right top turbo, do you guys think i could get 80 PSI boost?
VEfreak
Postby CumminsPride » Tue May 27, 2008 7:34 am
HX60 can usually be had from these guys for under 200 http://www.snoozulooz.com/
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby NYCEGUY01 » Tue May 27, 2008 5:51 pm
They might be a great place to deal with.
Whoever did thier site and music needs to be killed. LOL
96 chevy 3500 4x4 dually. 1st gen Cummins ,nv4500.
NYCEGUY01
Postby cummins king » Tue May 27, 2008 6:30 pm
NYCEGUY01 wrote:They might be a great place to deal with.
I agree,
the hx60 is un upgraded HT60
93 4X4 auto
cummins king
Postby bgilbert » Tue May 27, 2008 6:35 pm
HT60's are dirt cheap, but hx60's are high dollar. HT is reverse rotation, hx is not;). What is the correct term for that style :? ? The hx60 could possibly make it easier to plumb. Ht3b is reverse as well. I'm gonna be running a 66 s300/14 and a s400.
Bill Gilbert
bgilbert
Postby VEfreak » Tue May 27, 2008 9:15 pm
What about an HC5A atop a WH2D. Spool wouldn't be that great, but with enough porting and fuel, the boost would be fricken incredible, in theory. I know the HC5A is monstrous and i've seen it as the bottom in setups that crank at 150 lbs of boost. I think it might be to big though, seeing as how a s400 was the top turbo. :shock: But does anyone here have any experience with the k31's? And an hx 60 is something to be considered. I'm just searching out a setup that will pump out 80 pounds of boost with the right fueling, something to make a full dyno pass with a four speed OD, or i might just change to a friggin stick, who knows.
VEfreak
Postby cummins king » Wed May 28, 2008 4:30 am
bgilbert wrote:HT60's are dirt cheap, but hx60's are high dollar. HT is reverse rotation, hx is not;). What is the correct term for that style :? ? The hx60 could possibly make it easier to plumb. Ht3b is reverse as well. I'm gonna be running a 66 s300/14 and a s400.
Yes thats right also, an ht60 will crank out more then 80 pounds of boost, and is good for 850 racing hp, and a hx60 is a bit better
93 4X4 auto
cummins king
Postby SNOOT » Wed May 28, 2008 8:07 am
I have a new S400 for sale but I do not know the specifics on it. I would have to messure it or get the part number for anyone that wants to know.
$600.00
1993 W350
SNOOT
Postby Begle1 » Wed May 28, 2008 9:19 am
So I hear that "K31" is just another name for "HX55". Is that correct?
From my research, the only twins that have used a HY35 as a top turbo used a K31 as the bottom turbo...
Postby KTA » Wed May 28, 2008 12:13 pm
A K31 is KKK branded turbo, it is not a Holset HX55 although they are similar sized. The K31 is a very good preforming turbo but has a pretty short life in race use.
Postby DTanklage » Wed May 28, 2008 12:50 pm
and a s400.
with what turbine?
is there only one size s400?
i thought those were avail in a bunch of diff configs
what do you guys think would be a good single turbo for a 450 hp p-pump truck? (still has to tow) (i dont care if its a little laggy, almost always above 1800 rpm)
a buddy suggested a silver something 62-74
DTanklage
