holset hx-40w
holset hx-40w
Postby apwatson50 » Wed Jun 04, 2008 8:16 am
I found a hx-40w as a good possible candidate, however I want to make sure it has the right size turbine wheel and housing size.
The number is 3596295, can anybody tell me the size of the turbine wheel? I am fairly certain that the housing size is a 16.
thanks, Aaron
92 Cummins, 4x4, 270K miles
apwatson50
Postby CumminsPride » Wed Jun 04, 2008 4:06 pm
It's a 60mm compressor and if you're certain that it's a factory 16cm housing then it's the sought after HX40.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Philip » Wed Jun 04, 2008 6:33 pm
The housing size is cast into the exhaust inlet side of the housing on the HX40's.
How many blades does the compressor side have. A Super HX40 has 7.
Make sure it has a T3 flange on it.
Postby cummins king » Wed Jun 04, 2008 8:01 pm
Philip wrote:The housing size is cast into the exhaust inlet side of the housing on the HX40's.
I love that turbo
93 4X4 auto
cummins king
Postby apwatson50 » Thu Jun 05, 2008 6:32 am
It has a 6 blade compressor, so 60mm, also has a 16 stamped inside the exhaust housing, and its wastegated. Supposedly from a volvo. I went ahead and got it.
Also the backing plate on the exhaust housing isn't the band clamp type, its a flange with I think 6 bolts, which is fine as I can plasma a flange and weld a piece of 4in to it. Then have the flange milled flat. Or I suppose I could just find a backing plate with the band type connection.
Hope it keeps my egt's cool!
apwatson50
Postby CumminsPride » Thu Jun 05, 2008 9:52 am
Just go get a good piece of 3/8 or 1/2" plate and drill the bolt holes and cut out the center. I didn't mill my torched flanges on my twins and I still have no leaks. I used some copper sheet and tapped out the gasket with a brass hammer.
CumminsPride
Postby apwatson50 » Thu Jun 05, 2008 10:38 am
I have access to a cnc plasma cutter, so i'll just make a .dxf file with all the holes and it'll be done.
I would imagine i'd be able to get the gasket from cummins, hopefully!
This is probably what i'd do as it'll be free.
apwatson50
