How can I make this job easier this time around? The plan was to remove the flexible pickup tube from the sender, replace the removeable plug on top the sender with one I had from a gas parts truck. Then put the bulkhead fitting in the bottom of the tank. I've had good luck with it there on my 89.
Here's an option to dropping your fuel tank to build a bigger fuel system. I decided to cut an access hole in the bed floor big enough to remove the fuel sender. Then with the sender/float assembly removed, siphon the fuel out. Then get under the truck, drill a hole in the tank. The 1/2" (-8an/jic) bulkhead fitting calls for a 3/4" hole. The tank is plastic and drills easily with wood boring spade bits. What's nice is after you drill the hole with a 3/4" spade bit you physically have to thread the fitting in. On all the systems I've done, none have been loose, they've all been very tight. Wish I could say the same about , ah nevermind. Rinse out any shavings that may have entered with ether or diesel fuel.
Have a helper hold the fitting under the truck with a wrench while you tighten the nut inside the tank through the new access hole in the bed.
Luckily I had plenty of extra fuel hose under the truck from the last time I did the system. Stretched it from the top to the bottom of the tank. Hooked up and now have gravity fed fuel at the piston lift pump.
For a 'clean' install, I have a truck bed in the yard from a 91 parts truck. I cut out a section of the floor slightly bigger than the hole I cut in the floor of my 91.5. Siliconed it and used self tapping screws to secure the new access 'door'. Paint to match or if you're lucky like me, they're already the same color.
Course for those of you with show trucks, this might not be the way you wish to do the job.
