Or should I not risk building it and just send it to CK
VEfreak wrote:Well i know that 14mm heads don't like to be revved high. If you add to that a longer stroke on the plunger it really won't like it. The longer travel means the pump will have less tolerance for rpm's. Plus, i would venture to say it'll create more heat to.
VEfreak wrote:beryllium?
Users browsing this forum: No registered users and 78 guests
