did i do something wrong?
Postby 1991cummins » Sun Oct 12, 2008 7:14 am
ok guys, this is the deal,
yesterday i minorly minory advanced my timing, about a sixteenth.
i also grinded my afc foot down a little bit and made some adjustments to the diaphram...
for one thing, the truck is fast as ^*%&&^ now :D
but it doesnt wana rev down very quickly...
its really strange, if i rev it up, it slowly comes down and if i am driving down the road and just take it out of gear it hangs out at cruisin rpm for a while, if i punch it and hall *&^ and let it boost up to 40 pounds, and take it out of gear it drops like normal... could i have done something when i ground out that foot???
anything helps, thanks guys
Derek
and sorry for the book :oops:
1991cummins
Postby 1991cummins » Sun Oct 12, 2008 7:17 am
i also turned the full power screw in quite a bit, up past the chollar and on to the last few threads. could i be flirting with runaway and its doing this?
what mechanicly causes runaway? i am curious...
1991cummins
Postby Philip » Sun Oct 12, 2008 7:54 am
Turn the fuel screw back out some. Your close to the runaway point.
The other items you did wouldn't cause the problem your having.
Postby 1991cummins » Sun Oct 12, 2008 7:59 am
ok, thanks... will do, what do you think, a quarter turn?
1991cummins
Postby Philip » Sun Oct 12, 2008 12:29 pm
Myself I would go at least 1/2 turn. Then test drive agin. If the RPM is still hanging. Back it out some more.
Postby JQmile » Sun Oct 12, 2008 7:01 pm
I'm having the same issue with my truck. With the fuel screw turned all the way up, I can't even put the truck in neutral when I am running along, or it will run up to the governor. It sucks because I gained 25hp on the dyno from that last 1/2 turn that makes it freak out. I'm going to try a bigger set of injectors soon as a way of getting more fuel in without having the pump turned up quite as much.
JQmile
Postby 1991cummins » Sun Oct 12, 2008 8:40 pm
thats the way to go lol, plus it doesnt hurt your pump, its hard on a pump to shove fuel through a small hole, rather than flow it through a properly sized hole... from what i have heard
1991cummins
Postby 1stgencummins » Fri Mar 27, 2009 7:15 pm
I had the same thing happen to me and i backed my fuel screw out a 1/2 turn and it solved everything. but it depends how far yours is turned in. so just turn it out till it stops reving down high
1stgencummins
Postby CumminsPride » Sat Mar 28, 2009 3:41 am
It doesn't sound like runaway to me. It doesn't do it under every circumstance. I'd say more like throttle binding associated with the pump top being removed for the afc mod. Just speculating.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Begle1 » Sat Mar 28, 2009 6:48 am
I shifted into neutral instead of overdrive at 2800 or so RPM the other day.
It's funny when I do that on this truck, because even after I take my foot out of it the engine stays at the same RPM, but I'm not going anywhere. :lol:
Postby RumbleFish » Sat Mar 28, 2009 6:51 am
i once shifted into reverse instead of neutral at 45mph in my 85 gasser once. i dont recommend it.
Users browsing this forum: No registered users and 77 guests
