The 2nd gen LP regulated is what I'm dumping. Not that it doesn't do a good job, it's just that I'm moving out of it's league.
IMO, it will not reliably support the 6x18's (@ WOT).
At this point in time, I'm running . . .
- Regular DDP4's (not the plus model).
- Typically maxed VE IP with a 3200 gov spring and Denny-T fuel pin
- The above is timed at about 2.25mm.
The current Lp system is . .
- AN6 supply from pick-up in tank to the IP.
- Stock/OEM 1996 CTD piston LP.
- Aeromotive bypass type regulator just before the IP.
As such I'm able to pull the fuel pressure down low enough that with getting off the fuel at the end of a pass, more often than not, the engine will die and need the injector lines burped to get it running again.
I think the 2nd gen LP regulated is an excellent choice for a mild to moderately fueled truck up to approx 350hp (in the general scheme of 1st gens).
I'm gonna go ahead and sneak in a Walbro 392 and be done with it.
