what turbo housing?
what turbo housing?
Postby clubcustoms » Fri Oct 24, 2008 6:20 pm
I have a 90' w-350 w/ a getrag and have tweaked the pump a little and im now trying to figure out wich turbo housing to buy. I think Ive narrowed it down to a 12 or 14cm but what about a wastegate? Do i need that or what? Please give me some direction here...
clubcustoms
Postby RumbleFish » Fri Oct 24, 2008 6:40 pm
i had a gated 12 on my old crew cab and loved it, but it was on a hx35. my D350 will probably get one eventually.
Postby 1991cummins » Fri Oct 24, 2008 10:16 pm
i had one too for a while, but i didnt even have that much fuel and my pyro didnt like it... if i were you i would get a 14, but you wont be upset with the results either way, both will be a great improvement over your current housing for sure... you will feel it in the seet of your pants, and thats always nice
:D :evil:
1991cummins
Postby clubcustoms » Sat Oct 25, 2008 6:00 am
Thanks guys...maybe ill go with the 14 so i can add some fuel...how about the wastegate or non-wastegate options?
clubcustoms
Postby CumminsPride » Sat Oct 25, 2008 9:30 am
I don't think the $ is worth the extra 2cm. I would just run a 16cm housing without the gate and pour the fuel at it.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby cedardiesel » Sat Oct 25, 2008 6:58 pm
The 14cm2 is perfect and worth the money but the for a wastegated housing it's wasted money for price so go with a 14cm2 nonwastegated
90 W250 4x4 5spd pump Ve cranked wide open, BHAF, HX35 with all 2.5" intake piping, and 4" straight piped
92 W250 4x4 5spd P-pumped B1B over B2 are on and now slippy clutch
cedardiesel
Postby VEfreak » Sun Oct 26, 2008 8:17 am
get the non gated 14 and put an external waste gate on.
I AM ZUES DAMNIT
VEfreak
