Beginners starting line.
Postby slingshot » Thu Oct 30, 2008 5:42 pm
As you may have read in my welcome thread, I am new to this site, and as most newcomers do, I need advice as to where to start. I am not looking to have the most power on the block or be the first one up a hill, but when I hook on to a 35' gooseneck with a 20,000lb load on it, I would like to pull it a little better than it always has. After reading tons of stuff, I figured that lots of people are looking for power for different reasons and applications, so I just want to do things on the cheap that will help and not break the bank. The truck is a 93 W250 with the factory i/c,K&N airfilter in the factory box and 4" exhaust w/out muffler.The pump was untouched until recently when I took the fuel screw out and removed the collar then added two turns from where it was. After I did that, the motor would not idle below 1000rpm. With the idle screw backed out enough to not touch anything and the idle would not come down, I backed the screw out 1 turn and that is where its at now. I also rotated the factory fuel pin to where it is farthest from the shaft. I am going to pull my pump off soon and reseal it because the governor shaft is leaking,so while I am there I will install the governor spring that I got with my gasket kit. What should I look at doing for the next few things? I really cant afford a new turbo or injectors right now, but I do have an extra turbo from a 94 cummins in my shop.
1993 W250 5speed.
slingshot
Postby VEfreak » Thu Oct 30, 2008 6:20 pm
Backing off the idle screw may not be enough to lower the idle. You may have to loosen up the throttle linkage on that little metal bar that is threaded on both ends. If you turn up the pump enough, your gonna probably want to reindex the throttle shaft.
I AM ZUES DAMNIT
VEfreak
Postby RumbleFish » Thu Oct 30, 2008 6:37 pm
you DO have gauges, right?
Postby Ace » Fri Oct 31, 2008 5:22 am
Water/meth with a big resevoir is a great thing to have on a truck that tows heavy.
Ace
Postby 1991cummins » Fri Oct 31, 2008 7:16 am
honestly first thing is gauges, at least a pyro... water meth is a good thought too and a bigger intercooler... and once you get that if the pump mods are not enough, you will want injectors... i am not sure if they put the hx-35 on 94's but if it is, you will probably like the switch alot...
1991cummins
Postby JQmile » Fri Oct 31, 2008 4:00 pm
I'd say gauges, timing bump, and start saving your pennies for injectors. They help out the i/c trucks a lot as far as power goes.
JQmile
Postby slingshot » Sat Nov 01, 2008 3:58 pm
I have a pyrometer and manifold psi gauge. I have not hooked the pyrometer up yet though. I need to weld a bung in the exhaust pipe in order to complete that. I will check to see what that other turbo is later.
1993 W250 5speed.
slingshot
Postby PToombs » Sat Nov 01, 2008 4:54 pm
Put the pyro in the manifold. If you put it in the pipe, you can cook the engine and the pyro will read ok. After turbo is at least 300* cooler than before.
Postby 1991cummins » Sun Nov 02, 2008 9:35 pm
plus you get no response... i had mine mounted after, and never saw anything above 12 and it took forever to get there on a hard pull... then i moved it, and dear god, i would jump up to 12.5 quick and rise the 13.5... if i had my pymp turned up higher i could have cooked some goods and never even known it was coming...
1991cummins
Postby slingshot » Mon Nov 03, 2008 4:06 am
where have you guys been putting them at on the manifold? Every one of my big trucks have got them mounted about 5" after turbo. I wonder if I should change those too?
1993 W250 5speed.
slingshot
Postby GO OVRIT » Mon Nov 03, 2008 3:02 pm
The rear side just before the turbo. I always take the turbo off, but some people drill in steps with the engine running.
GO OVRIT
Postby PToombs » Mon Nov 03, 2008 6:06 pm
Just before the turbo, on the back 1/2. There is a divider in the middle. Most people drill the rear, but the front is ok too.
Postby slingshot » Tue Nov 04, 2008 4:21 am
Pictures anyone?
1993 W250 5speed.
slingshot
Postby slingshot » Tue Nov 04, 2008 6:30 pm
Anyone got a link to a thermocouple install on the manifold?
1993 W250 5speed.
slingshot
Postby PToombs » Tue Nov 04, 2008 7:00 pm
Her is a brief description, and a nice diagram for ya. This should hook you up good. ;-)
http://www.pdrdiesel.com/oldsite/TechPyroInstall.htm
