injector part number
Postby rattlebox93 » Mon Nov 10, 2008 10:39 am
The tip itself has "6814" on it.
On the body of the injector there is "KDAL 59P6 663" stamped on it. It also has "939" in a circle on it. Of course, it also has "260bar" stamped it but I know what that means.
Near the top of the injector body, just underneath the threads, there is "6818" stamped in it.
It is a 5 hole injector.
Anyone have any idea what injectors these are
rattlebox93
Postby rattlebox93 » Mon Nov 10, 2008 10:58 am
ok i know the part number is for a p pump 175 and 180 horse injector and they are 5 hole i have heard that the stock 180 injector is 3 hole what do you guys think?
rattlebox93
Postby KTA » Mon Nov 10, 2008 3:21 pm
The stock 180 tip is not a 3 hole and those most likely offer no performance advantage over what you have.
Postby rattlebox93 » Tue Nov 11, 2008 12:36 pm
but for 50 dollars would be a excellent buy for a core set
rattlebox93
