#$%& TIMING!
#$%& TIMING!
Postby 1991cummins » Sun Nov 16, 2008 12:45 am
ok, i want to bump my timing, i have tried at least ten times with everything i have in my shop full of tools... i cannot get those three stupid nuts loose... so i give up, where can i get the "s" wrench, or how about a picture of it or something...
Thanks,
Derek
1991cummins
Postby burnt_servo » Sun Nov 16, 2008 3:32 am
is there not a bracket on the pump head as well ?
'93 w250 .... stock ...
burnt_servo
Postby Begle1 » Sun Nov 16, 2008 5:55 am
The bracket's easy to get to, the one back behind the pump requires an S-wrench.
I got a set of metric and SAE reversible Gearwrench S-wrenches from Sears for $120...
Then I spent another $100 for a set of metric and SAE Gearwrench halfmoon wrenches...
Postby PToombs » Sun Nov 16, 2008 7:29 am
Try a swivel socket, or DPuckett got his with a crows foot and a few extensions.
I used the blue flame tool and made me a custom bent wrench.
Postby Philip » Sun Nov 16, 2008 7:31 am
Postby Makaio » Sun Nov 16, 2008 7:51 am
Ditto on the link Philip posted. I have a Snap-On pump wrench and it fits like a charm.
Matt
1992 W250 auto, ASA/AFE intake, H1C hybrid 60-16, Bosch 190's, Bully Dog fuel pin, 366 spring, modified pump and a 4" turbo back exhaust. Suncoast valve body plumbing 3.54's w/LSD. Autometer gauges.
Makaio
Postby VEfreak » Sun Nov 16, 2008 11:49 am
my buddy just unbolted his power steering pump and got at the back bolt with a regular ratchet.
I AM ZUES DAMNIT
VEfreak
Postby Begle1 » Sun Nov 16, 2008 3:54 pm
VEfreak wrote:my buddy just unbolted his power steering pump and got at the back bolt with a regular ratchet.
But that's just way, way, way too much work. :roll:
Instead of doing that I wasted an hour or so the first time trying to put a stubby wrench on it and hit the stubby wrench from down under with a hammer and two foot punch.
I actually got it off the first time with a universal joint and a socket, but I couldn't put it back on that way without torquing off the socket.
But without a S-wrench, it's a power steering/ vacuum pump removal job.
Postby randyswelding » Sun Nov 16, 2008 6:01 pm
heres what i did got a cheapy 13mm wrench and heated it up and made an s wrench.wala a maybe 15 dallor tool(torch gas and tool its self) and be done with it :D thats my opinion good luck either way ya go
'92 D350 cab and chassy,pump turned up with 1/8 timin,coaltriann 6x16 sticks,htt manifold,asa intake cooler tubez,south bend 13" clutch rebuilt G360,ps cooler,industrial super 62 phat shaft turbo,weldin bed.
12 Chevy 3500ltz lifted, deleted, and bed with sae 300 ss hood for new rig
randyswelding
Postby gear jammer 91" » Sun Nov 16, 2008 9:43 pm
Check your local tool stores, I found a half moon wrench set for $20 at the local MCK Tool.
01 LB7
gear jammer 91"
Postby 1991cummins » Sun Nov 16, 2008 9:44 pm
thanks for all the help guys, i will try the torch method considering between me and my dad have at least 5 complete sets of standard wrenches :lol: and if that dont work i will just buy the one philip showed me.
thanks,
Derek
1991cummins
