How to stop exploding turbos from going to an engine
Postby cummins king » Tue Nov 25, 2008 9:41 pm
I'm starting to work on my truck and i'm looking for some ideas on how to stop the turbo shards from going into my air to air cooler or even into my engine.
I'm just getting a bit worried because of the boost i'm building and i don't want to wreck the motor, if one breaks
I was thinking of some wire mesh welded into a pipe after the turbo but before the air to air.
Any ideas would be great!
93 4X4 auto
cummins king
Postby RumbleFish » Tue Nov 25, 2008 9:49 pm
take the turbos off?
Postby DTanklage » Wed Nov 26, 2008 3:41 am
oh, i dont know about that....
i would imagine its pretty easy on turbos sitting in the field with a blown head gasket
DTanklage
Postby cummins king » Wed Nov 26, 2008 4:21 pm
haha, funny, its in the shop in pieces.
! don't need any smart a$$ comments just help and if you don't have any then stay out!
93 4X4 auto
cummins king
Postby PToombs » Wed Nov 26, 2008 4:28 pm
CK, what do you expect from a 2nd gen guy? ;)
I wonder if you could fab up a bucket like thing, something that swirls the air and separates anything heavy in the airflow? Like a centrifugal strainer.
I think it will add a lot of turbo lag though with the extra plumbing.
Postby cell » Wed Nov 26, 2008 5:12 pm
Intercooler should stop the big chunks right?
cell
Postby redneckroot » Wed Nov 26, 2008 5:29 pm
I think you need something that would shut the air off or devert it like the traps you can put on exhaust so you can flip a switch and run open headers or full exhaust. The problem would be having something that would sensor turbo malfunction.
redneckroot
Postby cummins king » Wed Nov 26, 2008 9:43 pm
redneckroot wrote:I think you need something that would shut the air off or devert it like the traps you can put on exhaust so you can flip a switch and run open headers or full exhaust. The problem would be having something that would sensor turbo malfunction.
Maybe i'm just over worried about the idea, the air to air should stop most of it,
But good ideas
93 4X4 auto
cummins king
Postby KTA » Thu Nov 27, 2008 9:29 am
I had a wastegate malfunction one time and ran over 95+psi. I didn't blow any turbos up even at that level, but I did blow my exhaust apart. LOL In a twin setup you are pretty safe to 110psi or so if your turbos are balanced which yours should be close to being. Now a single pushing 60+ is a time bomb.
Postby bgilbert » Fri Nov 28, 2008 5:02 pm
Yeah I don't think you're building much boost to be worried about it. I think about the only thing you can do is not use junk turbo's. Even though a brand new high dollar charger will pop as well. Most junkyard chargers with high miles aren't the best thing to use when you're chasing 700hp, #2 only :roll: :lol: .
Bill Gilbert
bgilbert
Postby cummins king » Fri Nov 28, 2008 9:10 pm
True but they are both rebiult. and it wouldnt suprize me if i could hit 90 to 100 psi
93 4X4 auto
cummins king
Postby DTanklage » Sat Nov 29, 2008 2:24 am
did i hear gilbert correctly ? suggesting new parts and saying you should use the best of the best to boot ? what has bills old lady done with the real bill ???????????? lol
i think it is actually cheaper to do it right the first time
will be in the long run anyways
but the best benifit of using great stuff is that you get to use great stuff!
thats why bosch manuf the p-pump ! ! ! ! ! !
if you have not tried tuning one of those you have no idea what you have been missing out on. wonder how many big singles a tweaked out p pump has kilt?
how about ve motors? how many big singles have been granaded behind a small mech rotry?
DTanklage
Postby PToombs » Sat Nov 29, 2008 5:59 am
P-pumps are wayyyy overrated. Uusally by their owners! ;-)
Postby Richie O » Sat Nov 29, 2008 6:24 am
I have a 97 p pump. I don't waste my time talking about it.
Postby Begle1 » Sat Nov 29, 2008 8:06 am
What if you bubble all of the air from the turbo through a water reservoir, like a bong?
