guys need a quick answer to a question
Postby roxxx » Fri Nov 28, 2008 1:45 pm
I have my 4 inch skyjacker lift on except ... I bought the new springs 6 inch in the rear and the box kit came with a 2 inch block now the guys who are installing the springs seem to think the block should go in .... I don't think it does..... anyone know for sure ????? thank you
1992 4x4 Reg cab LE 5 speed
4 Inch lift
Bilsteins shocks 5125
VE moderately molested
Dana 80
ultra wheel rims Type 164
ASA pipe BHAF 19037
Outerwears prefilter
A A nv4500
roxxx
Postby Raymo » Fri Nov 28, 2008 2:38 pm
It's kinda wierd that a set of 6's have a block, but alot of rear lift springs come with short blocks for pinion angle. Like for instance, my 12" skyjacker system for my chevy were 8" springs with a 4" block, and the normal 12's in the front.
'94 Chevy 3500-HD cab and chassis- IC Cummins, Getrag, NP205. 60 front, 80 rear- 4.10's.
Raymo
Postby dpuckett » Fri Nov 28, 2008 4:32 pm
Dont most 1stGens have a 4 or 6" block on the rear? My 3 or 4 4x4s have all had blocks of one sort or another.
Daniel
Postby Ace » Fri Nov 28, 2008 4:58 pm
The 6" rears match up with the 2 1/2" fronts, no blocks. They probably don't have an 8" rear, so they just throw in 2" blocks for the 4" kit. That would be my guess anyway, without knowing exactly what you ordered.
There should be a pair of shims to rotate the pinion up off the perch a few degrees and maintain a decent pinion angle.
Ace
Postby roxxx » Fri Nov 28, 2008 6:23 pm
the kit is a 4 inch kit 4 up front and 6 in the back i was hoping for a block delete
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby florida4x4 » Fri Nov 28, 2008 7:15 pm
blocks in the rear might sound like a hack but it helps keep the spring pack flatter and will ride better. blocks in the front are always a very bad idea..
Florida4x4 forum
1972 GMC Jimmy | 1-tons | doubler | 42" Swampers | Stazworks Beadlocks
1993 W250 CTD | 4.10's otherwise all stock for now
florida4x4
Postby oldcool90 » Fri Nov 28, 2008 9:33 pm
I have a 4in skyjacker lift on mine and 4 in springs front and 6 in springs rear with no blocks is the way my 90,s set up.
oldcool90
Postby GO OVRIT » Sat Nov 29, 2008 6:46 pm
The 92 and 93 trucks had the 6" factory blocks, so 2" blocks with 6" springs should get you level with 4" springs in the front. Stock they sit about 2.5" high in the rear.
GO OVRIT
Postby jimmyt83 » Sat Nov 29, 2008 9:16 pm
It all depends on the kit you ordered bro...it's really hard to say without knowing the part number for the kit you ordered. I'd say it needs to be in there for the truck to sit right...otherwise you wouldn't have gotten it. All of the above posts bring up various points as to why blocks aren't so bad...I'm not a big fan of blocks, because I've seen them shatter...but it all really depends on how you're using it. It really sounds like you ordered the wrong kit...if you'd need 8" springs to make it sit level, they are out there...you can get anything with enough money.
For a professional answer, call 4wheelparts and ask for their tech support. If they don't know the answer, they'll call the manufacturer with you on the line. Excellent service from them every time I've worked with them.
'94 Chevy K1500, '93 IC CUMMINS Conversion, A518 (upgrades to come), 1-ton SAS, 3.73 gears, 39.5" Boggers on 15x14 Pro Comp wheels
jimmyt83
Postby DTanklage » Sun Nov 30, 2008 11:46 am
remember when i was gonna have bushings made to properly fit the eye in the rear spring
still cant believe you guys didnt want to do that
how bout you trip x?
you 1 ton or 3/4?
have ya checked out the fit yet?
tank
DTanklage
Postby roxxx » Sun Nov 30, 2008 4:51 pm
it s a 3/4 ton and the part # of the springs are s97d400cs Front 4 inch .... rear 6 inch s97dr60s
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby DTanklage » Mon Dec 01, 2008 2:30 am
iirc there is not a bushing prob on the 3/4 ton springs
DTanklage
Postby roxxx » Mon Dec 01, 2008 3:32 pm
actually there was. we had to press the skyjacker bushings out and but in some new ones
4 Inch lift
Dana 80
ASA pipe BHAF 19037
A A nv4500
roxxx
Postby DTanklage » Mon Dec 01, 2008 8:07 pm
push in some new bushings from who???????
that was the whole deal...i couldnt find any that fit both the eye and the bolt!
if you found some it should be a sticky in the suspension forum
DTanklage
