How much power?
How much power?
Postby MudSlinger79 » Thu Dec 04, 2008 9:03 pm
I have a 92 cummins i put a set of New Era 435s ,cranked pump, a 66/71 turbo, and a intercooler off of a motorhome which measures 20x30", 366 spring and afc lever mia. What kind of power do yall think it will make i havent fired it up yet. Just trying to get a idea of what it will make.
MudSlinger79
Postby DTanklage » Thu Dec 04, 2008 10:11 pm
375-425 hp
that turbo might be a little large for the fuel you are throwing at it
DTanklage
Postby MudSlinger79 » Fri Dec 05, 2008 5:28 am
I know but i plan on upgrading that in the near future. A 14mm pump and maybe some bigger injectors. I was gona get a 62/71 or 64/71 but i got a good deal on the 66/71.
MudSlinger79
Postby DTanklage » Fri Dec 05, 2008 1:09 pm
MudSlinger79 wrote:...maybe some bigger injectors.
maybe?
lol
DTanklage
Postby MudSlinger79 » Sat Dec 06, 2008 6:47 am
what would u recommend?
MudSlinger79
Postby 92d250 » Sat Dec 06, 2008 8:24 pm
6x16's
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby DTanklage » Mon Dec 08, 2008 11:08 am
or bigger...
do you have a case pressure gage?
those things will suck your ip dry in no time!
DTanklage
Postby MudSlinger79 » Mon Dec 08, 2008 1:22 pm
I dont have one of those gauges what is it? Similar to a fuel gauge?
MudSlinger79
Postby DTanklage » Mon Dec 08, 2008 4:54 pm
its just a pressure gage
i suggested a while back that everyone that 'hod rods' a ve install one
a gage to tell you how much case pressure you got
(you can have pressure but not volume in some areas of the system, but not in the case itself....if there is pressure there, there is fuel there...hope that makes sense)
good luck! don
DTanklage
Postby DTanklage » Mon Dec 08, 2008 4:55 pm
ps - the gage you need will need a range of 100-300 psi
0-300 will be fine
DTanklage
