KTA wrote:My pump must be fubarred. It has the 386 spring at it fuels past 4200rpm, and I have the only 4000+rpm 1st gen dyno sheet to prove it.
That's cause you drove it on Dunbar's dyno
. Dave woulda let off it at 3200ish when the power fell off
Guys, a dyno sheet will tell ya what's goin on, when the pump defuels etc. Sure a stock governor setup can rev to 4000 in neutral, (modified linkage, high idle screw backed out etc), but making power above say 3200rpm is tough.
I think the only reason KTA was still making power at 4k (not much from what I seen
) was because he was making SO MUCH HP already at 3000-3300.
Until I see someone prove (dyno sheet) that ANY modified spring will hold the HP curve well beyond 3200rpm or keep it straight etc, I say wipe your blanks with it. 3200rpm spring be done with, look to other means of raising the bar.
