bgilbert wrote:Don't waste your time with the 4200 spring. PDR should be ashamed for advertising that. It's too long and should be trimmed to the correct length to operate correctly. Key word is correctly.
Begle1 wrote:bgilbert wrote:Don't waste your time with the 4200 spring. PDR should be ashamed for advertising that. It's too long and should be trimmed to the correct length to operate correctly. Key word is correctly.
How do you "trim" a governor spring?
Greenleaf wrote:You need to understand that when you install the spring AND modify the trucks throttle linkage, you will see more than 3200 rpm's.
