by PToombs » Fri Feb 09, 2007 4:43 pm
My turn! I'd like to have up around or over 300 hp. The truck is a summer (mostly) daily driver, hot rod, and occasionly I tow up to 15k. I have- 3200spring, BHAF, 4" exhaust turbo back, Piston LP, drilled banjo bolts, original fuel pin, turned deep, Fuel screw is in some and can go in almost 2 turns, star wheel is bottomed and there is a valet on it, 16cm exhaust housing. I have a borrowed HX-35 on it, but I only drove it about 3 miles to test.
My very next thing is valve springs.
Questions; All the springs, or just exhaust?
Is the HX-35 the hot ticket, or PDR HX-35? Or call HTT and get just a compressor wheel and housing (what size?) for my H1C (15K miles)
What injectors? or tips? I am going to talk to my pump shop guy and see what it will cost to build something. I want more than PODs and a little cleaner.
Any advice the high horsepower gurus can give will be appreciated!
