New Diesel owner 92 w250
Postby Swaggs » Sat Jan 24, 2009 11:49 am
Whats up, I just got a 92 w250 club cab diesel with a 5 speed and about 125k on her.. I am currently in iraq, so its at my brothers house, he is doing the tune up stuff on her, new brakes, man. hub lockers, and putting in a borgeson shaft.. I have alot of time, and some money to put in her.. I need some good ideas, and where to start.. I have restored a camaro, and worked on just about everything, but diesel is pretty new to me.. Im thinking, gauges, fuel pin, injectors, VE pump tweaks, exhaust, intake, and the cooler tubes.... I hear that the weakest part of my truck is the getrag, how correct is that, how much can it stand up to? anyways guys, anything will help, i have about 2 more months over here, and then the fun starts.. later guys..
Swaggs
Postby Richie O » Sat Jan 24, 2009 12:22 pm
Thanks for serving!!
The getrag should be fine. The rest of ideas sound good.
Postby Swaggs » Sat Jan 24, 2009 12:42 pm
Thanks, so a few more questions.. injectors.. there are so many choices.. I want a good daily driver, that isnt going to smoke too bad, and that doesnt raise egts up too bad.. also, how do you guys get the little picture under your title?
92 W250 CTD, Getrag, hx35, DiamondEye, Mostly Stock
89 Ramcharger 360/727
'92 W250 CTD, Lifted Sold
'96 2500 CTD Sold
Swaggs
Postby Richie O » Sat Jan 24, 2009 3:35 pm
I will let some other guys answer the injector question. I am still running stock ones so I have no experience with aftermarket ones. As far as the picture, go to the top of the main page and click on profile. Scroll down to the bottom and you will see the avitar control section. If you want a picture it must be real small size. I had to resize mine to get it to work. I don't remember all the steps but that should get you started.
Postby peobryant » Sat Jan 24, 2009 5:55 pm
Swaggs wrote:Thanks, so a few more questions.. injectors.. there are so many choices.. I want a good daily driver, that isnt going to smoke too bad, and that doesnt raise egts up too bad.. also, how do you guys get the little picture under your title?
If you want bigger injectors, than you better start looking at a bigger turbo as well. With the stock H1C and bigger injectors, things will get a little toasty.
Another mod you may want to consider for your truck is the 366 spring. It replaces the stock governor spring, and allows the pump to fuel up to 3200 RPM's.
Postby Swaggs » Sat Jan 24, 2009 10:37 pm
ok, thanks guys.. yea, i have been looking around. i made a shopping cart at like pdp or somewhere, for the gauges and the spring, what do you guys think about the fuel pins? Diesel power mag just turned their stocker like 270 degrees and left it.. but, i was looking into those too.. So, a good turbo is an hx35?
'96 2500 CTD Sold
Swaggs
Postby Richie O » Sat Jan 24, 2009 10:57 pm
Turning the fuel screw is a slight help. Don't assume you have to turn it a certain degrees. Mark where it was and take it out. Look for the deepest part of the pin. Turn it in your hand and you will see what I mean. You want to install it so the deepest is facing the front of the truck. Mine was only about 20 to 30 degrees from deepest. I did not really see any noticable gains. You can grind you pin to make it fuel harder. I think I am going to get a denny t or something like it. A hx 35 is slightly better then your stock rig. You would be better off getting a GDS 60mm upgrade compressor. After that you would step up to a hx 40 and slightly more money would be the entry level to the S300 borge warner turbo. It depends on what you want to spend.
Postby peobryant » Sat Jan 24, 2009 11:59 pm
As far as fuel pins, the best one on the market is the DennyT Stage II Fuel pin. I know a lot of guys just grind the stock pin, but I believe that even a heavily ground stock pin won't fuel as much as the DennyT pin.
An S300 would be a very good turbo, but they are a little costly. But it's better to spend the money once. 8)
Postby Swaggs » Sun Jan 25, 2009 5:46 am
alright thanks.. I will look into that.. I am trying to make the most power without negatively affective driveability.. So all the help is appreciated.. I am headed home in march, so I will get to see her, and play around a little bit.. I am trying to spend too much on it right now, i have a jeep with a lift kit waiting to go on, and a wedding this fall.. so, thanks guys.. I will keep the questions coming..
'96 2500 CTD Sold
Swaggs
